Ok, so, it's really cold - below freezing - and I recently went to get some groceries for my dorm room at Walmart and noticed my trucks oil pressure gauge fluctuating on low to no oil pressure. For perspective, Walmart is 2 miles from my campus. When I start my truck the gauge shows no oil pressure. It fluctuate between reading normal pressure and no oil pressure until my temp gauge reads above cold, which it will read above cold after about a mile of driving.
My question is, do you think that there might just be a problem with the gauge - I've been told that Ford's oil pressure gauge is not the most accurate, and when it is less than like 5 or 10 psi it just won't read anything - or do you think that there is something wrong with my truck? I have Kendall GT1 semi-syn 5w-30 in it, btw.
