The October issue of LUBES'N'GREASES had an excellent article by Dr. Jack Zakarian, titled
"V.I. Too Resistant to Change" that was captioned and discussed in the following post:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3148253/1
The gist of the piece was that Jack Zakarian was quite critical of the method detailed in ASTM D2270 by which the V.I. of an oil is calculated.
He summarized as follows:
"ASTM V.I. does not accurately represent the "real V.I." of oil .... the rating method suffers from a number of inconsistencies that penalize lower viscosity oils compared to their higher viscosity counterparts. In addition, V.I. has no fundamental relationship to the true viscosity-temperature behavior of an oil, even though it is widely presumed to have one. At best, V.I. ia a very rough guide to viscosity-temperature behavior.
By understanding the deficiencies in the rating method, users will be better able to interpret and understand the actual V.I. numbers."
So I got to thinking, how can we avoid the V.I. penalty that applies to lower viscosity oils and determine the "REAL V.I." regardless of how thick or thin an oil actually is?
One method that does avoid this problem occurs when an oil's viscosity that's based on the same KV40 and KV100 spec's used to calculate it's ASTM V.I. are plotted on a graph commonly used in viscosity calculators. When you graph oils with different viscosities you are comparing the oil's "REAL V.I.".
But what we need is a "REAL V.I." number to replace the ASTM V.I. number. What better than using a ratio of KV40/KV100? We could also use the reciprocal but I think whole numbers are more insightful than fractional numbers.
For example M1 0W-40 (ASTM V.I. 185) has a KV40/KV100 ratio (75cSt/13.5cSt) of 5.56, meaning it's kinematic viscosity increases 5.56 times as the temperature drops from 100C to 40C.
M1 5W-30 (V.I. 172) has a ratio (61.7/11.0) of 5.61.
M1 0W-20 (V.I. 173) has a ratio (45.8/8.7) of 5.26.
Although the lighter M1 5W-30 has a significantly lower ASTM V.I. it's viscosity change with temperature ratio is only slightly higher and the even lighter 0W-20 actually has a lower ratio or a higher "REAL V.I." to M1 0W-40. That is an example of the V.I. penalty that applies to lower viscosity oils that Dr. Zakarian was referring to.
Just for fun, I've ranked a bunch of oils based on their KV40/KV100 ratios representing their "REAL V.I.'s" from the lowest to the highest:
Joe Gibbs XPO 0W-5, race oil, PDS spec's - ASTM V.I. 170, 11.5cSt/3.3cSt = 3.48
RL 0W-2, race oil, PDS spec's - V.I. 136, 11/3 = 3.67
Marvel Mystery Oil, PDS & VOA - V.I. 96, 10/2.64 = 3.79
Sustina SN 0W-20, PDS - V.I. 229, 32.69/7.94 =4.12
Mazda Moly SN 0W-20, VOA - V.I. 221, 35.85/8.37 =4.28
TGMO SN 0W-20, VOA - V.I. 216, 37.4/8.5 = 4.38
Motul 300V Sprint 0W-15, VOA - V.I. 155, 23.3/5.1 = 4.57
Honda (Idemitsu) SM 0W-20, PDS - V.I. 197, 40/8.5 =4.66
TGMO SN 0W-20/M1 SN 0W-20, 60/40 0W-30 blend, PDS - V.I. 203, 48.9/10.2 =4.79
Sustina SN 5W-30, VOA - V.I. 194, 51.5/10.3 =4.99
PP SN 5W-20, PDS - V.I. 169, 45.34/8.56 =5.30
Havoline Syn SN 5W-30, PQIA - V.I. 177, 53.5/10 =5.35
PP SN 0W-20, PDS - V.I. 164, 46.8/8.6 =5.44
PP SN 5W-30, PQIA - V.I. 171, 55.1/10.0 =5.51
PU Euro SN 0W-40, PDS V.I. 186 75.3/13.6 =5.53
Havoline Syn SN 5W-20, PQIA - V.I. 155, 47.5/8.44 =5.66
PYB SN 5W-20, PQIA - V.I. 155, 49.4/8.7 =5.68
Motul 300V 0W-40, VOA - V.I. 174, =5.86
GC 0W-30, PDS - V.I. 167, 72/12.21 =5.93
Castrol 0W-40, VOA - V.I. 165, 79.19/12.95 =6.11
PU SN 5W-40, PDS - V.I. 166, 80.7/13.2 =6.11
Shell T6 5W-40, PDS - V.I. 170, 87/14.2 =6.13
M1 SN 5W-50, PDS - V.I. 180, 108/17.5 =6.17
RL SN 5W-50, PDS - V.I. 186, 130/21 =6.19
Motorcraft 5W-50, PDS - V.I. 181, 108/17.5 =6.48
RL SN 10W-60, PDS - V.I. 187, 170/26 =6.54
PYB SN 10W-30, PDS - V.I. 135, 69.7/10.53 =6.62
Rotella T3 10W-30, PDS - V.I. 144, 80/12 =6.67
Mobil Delvac 1 5W-40, PDS - V.I. 151, 102/14.8 =6.89
Castrol TWS 10W-60, PDS - V.I. 174, 168/24 =7.00
Rotella 15W-40, PDS - V.I. 135, 120/15.5 =7.74
Widman Dino 20W-50, V.I. 121, 175/18.8 =9.30
Mobil Spectra Syn Elite 150 (base oil), PDS - V.I. 206, 1705/156 =10.93
If your favourite oil isn't in the above list it's easy enough to calculated it's KV40/KV100 ratio to determine it's REAL V.I. and see where it would slot-in in the above.
Light oils with low ASTM V.I.'s can have remarkably high real V.I.s while even high V.I. heavy oils don't have high real V.I.'s.
It is a basic characteristic of oil that the heavier it is the more it's viscosity will change with temperature.
Since 40 grade and heavier oils can't have high real V.I.'s it should give one pause to question whether they really need to run a 40 grade oil in the first place, and if they do to consider choosing a high ASTM V.I. oil such as M1 0W-40 which at least minimizes the fact that heavy oils are disproportionately heavy on start-up for the viscosity gains that are made at higher temp's.
