So I bucked the trend of using a larger oil filter and instead used a smaller oil filter.
The filter on the Taurus is behind the manifold on the engine and is harder than heck to get my hand down in there. Today I was getting ready to change my oil and I know this is going to be a shorter OCI due to oil pan gasket change, so I did not want to waste a FU, so I knew a FL-910s is almost identical to the FL-400s except that the 910s is shorter. Well it went on just fine and purred like a kitten when I fired it up. I might use the FL910S and equivalents on the Taurus in the future just because its a lot easier to get a hand on it and fit it in the tight spaces. I don't see any harm in using the smaller filter since I know I don't have a sludger on my hands.
