Originally Posted By: 440Magnum
Originally Posted By: mcrn
The cummins is the only one in this class that is a true medium duty as far as i know. The others are considered light duty.
Its definitely the most rugged of the 3, but in that class its not so much of a benefit since all three outlive the chassis. The Cummins just has more left in it when the chassis is scrapped. Move up a class or two, and then the Cummins shows its mettle.
FWIW, back in the 90s Austin/Travis CO EMS had Freightliner ambulances powered by 2-valve Cummins B5.9 engines. As far as I ever heard, they ran the wheels off of those without so much as a hiccup. But they were actually smaller and lighter than what they're dragging around with the F-450 these days.
And as to the question of the 6.0: I disagree. NOTHING makes it worth owning. Yes, you can make it hang together... more or less... but any engine that requires dropping the crankshaft to slide the cam out (out the rear of the block, no less) in order to replace a single failed valve lifter is J-U-N-K. Nevermind the issue of lifting the cab off the truck to get to the engine so you can drop the crank so you can change the lifter.... :-/
And judging by how many Ford *and* Navistar Maxxforce trucks I see laying down big, oily, white smokescreens when regen kicks in, I don't think that's ever been fully sorted out with the 6.4 either. Never have seen a Scorpion, Duramax, or Cummins do that. Kinda defeats the purpose of a DPF, dunnit?
Not just the Ford/IH thing: I watched a truck at work (2010 Freightliner, Cummins 6.7) do that a couple weeks ago. The yard horse (2013 Ottawa, Cummins 6.7) has been a catastrophe, now on its third DPF (and fifth trip to Cummins for a cleanout) in a year.
We also had a tractor (2011 IH, MaxxForce 11) doing a parked-regen in the yard suddenly start shooting FLAMES from the stack.
That one left on a wrecker and hasn't come back yet.
Diesel power has jumped the shark. I fervently hope that when my current pile at work (2007 Freightliner, 7.2 Cat) gets replaced (lease is up in March), it is with an F-650 with gas power. Yes, I am willing to give up my air brakes & standard shift to get away from a post-2007 diesel disaster!
