[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
02/13/16 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
02/13/16 07:16 PM
T rated General Altimax tires on 2012 Corolla?
by Corollaman
02/13/16 07:00 PM
Best container to store tools underground ?
by Merkava_4
02/13/16 06:45 PM
ESET antivirus - 3 years for $20
by greenjp
02/13/16 06:00 PM
Fram Ultra XG9972 11k Miles
by SF0059
02/13/16 06:00 PM
Antonin Scalia is dead
by skyactiv
02/13/16 05:04 PM
2003 Dodge Caravan rear wheel locked up
by Oldtom
02/13/16 05:03 PM
Kwik lift
by old1
02/13/16 04:55 PM
BJ's Mobil Super Synthetic on sale 6 qts/$22
by 69GTX
02/13/16 04:52 PM
Battery charging when its cold out
by Donald
02/13/16 04:48 PM
Alfa in formula one?
by Charlie1935
02/13/16 04:46 PM
Formula413, Cruzingoose, klob, beaglefet, bsmith3
56907 Registered Users
88 registered (90crvtec, 15SilvyEcotec, Al, 04SE, 2015_PSD, 07titan, 15 invisible), 1498 Guests and 139 Spiders online.
56907 Members
66 Forums
244659 Topics
Page 1 of 3 1 2 3 >
#3264767 - 01/30/14 11:06 AM Diesel oil to clean petrol engine?
Spetz Offline
Loc: Australia
I've heard of people saying to run diesel oil in a petrol engine to clean it out due to the extra cleaning properties in the diesel oil.
Is there truth to this?
Any disadvantages, or things to be careful of?
Recommended oils etc?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 130,000 miles
#3264779 - 01/30/14 11:25 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
NHGUY Offline
Loc: USA
Engine flushes are largely kerosene.
#3264785 - 01/30/14 11:30 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
Eddie Offline
Loc: Florida, Cape Coral
Not good for the cat converter because of increased zinc
CX5 Touring 2.5L :-)
#3264786 - 01/30/14 11:32 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
RobertISaar Offline
Loc: Camden, MI, USA
i've used kerosene to good effect before.
kerosene and diesel are so similar that i really wouldn't have a problem with either.
#3264787 - 01/30/14 11:33 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
expat Offline
Loc: Canada
Do you mean Diesel Fuel or Diesel Motor Oil?
#3264792 - 01/30/14 11:39 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Just a Quality LL synthetic will do the job. Better than 15w40 Fleet oil. STay away from Mg compound dps. Nasty residue.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3264805 - 01/30/14 11:48 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
Spetz Offline
Loc: Australia
Actually I meant using oil designed to be used in diesel motors, not actual diesel fuel
#3264817 - 01/30/14 11:56 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
expat Offline
Loc: Canada
Most HDEO's are rated for Gas or Diesel
If you don't mind 10w-30 or 15w-40 there are some very good HDEO's available.
I have used Rotella in my Triumph for years, My Toyota 22R also gets it in the summer.
#3264846 - 01/30/14 12:39 PM Re: Diesel oil to clean petrol engine? [Re: Spetz]
dparm Offline
Loc: Chicago, IL
Many diesel oils carry API SL/SM certifications, meaning they are safe for use in gasoline motors. I'm not sure they would clean any better than gasoline oils though.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3264875 - 01/30/14 01:02 PM Re: Diesel oil to clean petrol engine? [Re: Spetz]
turtlevette Online   shocked
Loc: Massachusetts
Yes, Diesel oils have more detergents and dispersants than gas engine oils. I'm using some M1 TDT I got cheap at AZ to clean up my old Trans Am engine. Run it until it gets dark, dump it, new filter then repeat.
USA-1
#3266551 - 02/01/14 07:28 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
fdcg27 Online   content
Loc: OH
There may be some merit to this idea.
HDEOs often have an add pack rich in magnesium which may be a more efficient detergent/dispersant than the caclcium which is usually the dominant detergency add in PCMOs.
Magnesium also incidentally gives better TBN retention than calcium.
If I were going to try this approach, I'd look at formulation and select an oil with plenty of magnesium and calcium to maximize the cleaning potential.
Still, unless an engine has been badly negelected or has suffered something like coolant leaking into the oil, there isn't usually much to clean up.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3266702 - 02/01/14 10:21 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
jamesyarbrough Offline
Loc: Denison TX
http://www.pqiamerica.com/May%202013/consolidatedhdeo.html
http://www.pqiamerica.com/March2013PCMO/Marchsyntheticsallfinal.html
But doesn't the new M1 5w30 have a lot of magnesium? And so does the Castrol line of synthetics if I recall...
if this is true the need for HDEO is negated, especially since some of the popular versions like rotella only have calcium now
Edited by jamesyarbrough (02/01/14 10:27 AM)
2006 F-150 M1 0w40 & Bosch
2004 Explorer M1HM 5w30 & Bosch
1986 Lincoln SA200 T6 5w40 & Wix
#3267510 - 02/02/14 02:34 AM Re: Diesel oil to clean petrol engine? [Re: Eddie]
Shannow Offline
Loc: Oz
If they meet "S" specs, then this isn't true...40s are allowed to have higher zinc, as less reaches the cat convertor through reduced consumption.
If 1qt of 20 or 30 per 1,000 miles passing through the cat is OK (as per OEMs), then any normal car with normal oil consumption, HDMO additive levels are no issue at all.
#3272109 - 02/06/14 05:56 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
ac_tc Offline
Loc: sweden
It works fine as cleaning oil...
It works fine as lubricating oil also...
And while it may not be the best for a catcon it wont killém either.
They have a tendency to turn black quickly if the engine isnt squeeky clean so dont change to soon.
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3272281 - 02/06/14 09:14 AM Re: Diesel oil to clean petrol engine? [Re: Spetz]
UG_Passat Offline
Loc: NJ
I use HDEO anyway in my petrol engine.
have you considered AutoRX? It used to be the rage on this forums
Page 1 of 3 1 2 3 >
