Originally Posted By: topsy
I've got a 2011 Kawi Ninja 1K (not the super sport ZX-10R bike). Manual says to replace oil at least once/year. The oil is Rotella T6 full synthetic, it's been in there almost a year, but only a little more than 1,000 miles.
Seems like a waste to change it, but I'm not sure I should let it go any longer than recommended.
Diesel oils have high TBN to combat acids. Because of this, they make excellent extended drain oils. T6 is no exception. It's a robust oil and will continue to protect your engine after 1, 2 and even 3 years at that rate of riding! If it were mine, I'd change at 2 years, and if you are really curious, perform a UOA with TBN. I'll bet a dollar you'll be pleasantly surprised at the TBN retention. (UOA not really necessary, as TBN will be just fine)
T6 does shear a bit in motorcycle engines (as do nearly all oils) , so 2500 miles is about the right time to change in trans shared sump engines.
