There was a multi-page article in the local paper today about mechanical breakdowns in the city's ambulance fleet- specifically breakdowns severe enough to prevent the ambulance from completing a dispatch. The vast majority of breakdowns are occurring in a batch of 2010 F-450 ambulances powered by the 6.4 Powerstroke in its last year of production. That tells me that they never did get that engine "right," as is sometimes claimed. An interesting factoid is that every single one of the fleet's F-450s has had at least one complete engine replacement, and at least one ambulance has had TWO complete engines swapped. Older F-350s with the 6.0 have actually done a little better, believe it or not. The fleet breakdown (critical enough to prevent completion of a dispatch) rate is 7.2 per 100,000 miles, and the statewide average of large city ambulance fleets is around 2-3 per 100k miles. If you take the 2010 F-450s out of the numbers, the local fleet is still just a little higher than the average, so there's probably a preventative maintenance problem too.
None of that is really news to anyone who's followed the Navistar/Powerstroke saga, but Ford is still making good on fixing them it would appear. And to rub salt in the wound, the city/county are going back to buying Cummins/Ram based ambulances again, and Ford had to recall their new 6.7L-powered ambulances last fall because a faulty EGR temperature sensor was shutting engines down and preventing restarting for an hour.
The article is only available online if you subscribe to the paper's website (I HATE that!) but they do have a summary teaser here
