2002 GMC Yukon Climate Control Problems
by Kgrant
12 minutes 7 seconds ago
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
Today at 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
Yesterday at 11:08 PM
GM Oil Life Update
by CapitalTruck
Yesterday at 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
Yesterday at 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
Yesterday at 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
Yesterday at 08:48 PM
why would someone want to pay with a phone?
by turtlevette
Yesterday at 08:16 PM
The connection was reset problem
by Triple_Se7en
Yesterday at 08:14 PM
BIG PROBLEM!
by Avery4
Yesterday at 08:03 PM
11,000 miles on a BMW
by BigJohn
Yesterday at 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
Yesterday at 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
40 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 611 Guests and 203 Spiders online.
56834 Members
66 Forums
244295 Topics
Page 2 of 3 < 1 2 3 >
#3224641 - 12/22/13 01:19 PM Re: JP-8 in a diesel [Re: Shannow]
fdcg27 Offline
Loc: OH
Originally Posted By: Shannow
Anywhere that sells 100% biodiesel...as long as it's pure and clean.
Hadn't thought of that.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3224751 - 12/22/13 03:34 PM Re: JP-8 in a diesel [Re: Shannow]
MolaKule Offline
Loc: Iowegia - USA
Or contact ADM or Acme Hardesty which both make good esters.
"Tyranny is defined as that which is legal for the government, but illegal for the citizenry." T. Jefferson smile
#3225844 - 12/23/13 06:47 PM Re: JP-8 in a diesel [Re: SrDriver]
JHZR2 Offline
Loc: New Jersey
Originally Posted By: SrDriver
All I know is when the switch was made from JP-5 to JP-8 in aircraft engines problems were many.
there was no such thing as a switch from JP-5 to 8. Both are active specifications for currently used fuels. JP-8 is a low flashpoint jet like Jet-A and actively used in army/USMC diesels and generators as well as terrestrially-based jet aircraft and gas turbine engines.
JP-5 is a high flashpoint jet fuel used in ships to operate sea-based jet aircraft, and can be used in place of DFM/F-76 high flashpoint diesel in marine gas turbines.
Both jets are currently dirtier (sulfur content) than equivalent distillate fuels. I'd be careful with the JP-8 additives.
#3227117 - 12/25/13 08:40 AM Re: JP-8 in a diesel [Re: Shannow]
Groundhog Offline
Loc: Wadmalaw island SC
Thank you all for the help, happy holidays
I'm going to go with it.
#3241506 - 01/08/14 07:45 AM Re: JP-8 in a diesel [Re: Groundhog]
FlewByU Offline
Loc: Florida
Some interesting developments in JP-8 as an altrnative deisel fuel.
The Army through the SBIR small business development award program has been working with Alternative Fuels Technology (Redmond MI) for the past several years on mitigating the valve wear problem caused by the low lubricity of JP-8.
Phase 1 and Phase 2 have been completed and they are now selected for Phase 3, commercialization. They did the work on the Bosch CP-3 common rail.
You can view the results of Phase 1 and Phase 2 R&D on the following link go to "filter: type "alt" and view the Alternative Fuels Technology entries. Army has selected them for phase 3 commercialization. More information about that process can be read at the SBIR Phase 3 commercialization brochure
https://portal.armysbir.army.mil/SmallBusinessPortal/Portal/SummaryReports/Default.aspx ......easy access by
#3264062 - 01/29/14 04:56 PM Re: JP-8 in a diesel [Re: Groundhog]
sixtwoturbo Offline
Loc: Abbotsford, BC
Use it, if not, bring it to me, lol. I know many guys running it, including me. An older Cummin's, 6.0 PS, etc.
If your concerned, just add some 2 stroke oil for some lubricity or a decent additive. You will lose some power so be warned about that.
1984 G20 Get A Way van, 6.2 diesel with a remote mounted turbo-HX35 with a billet 60mm HX40 comp wheel, 20 psi, running waste fuels and jet fuel.
#3375048 - 05/18/14 07:35 PM Re: JP-8 in a diesel [Re: Groundhog]
TiredTrucker Offline
Loc: Central Iowa
How much of a difference is there between K-1 kerosene and JP-5 or JP-8?
Burn it down.
#3764290 - 06/18/15 02:26 PM Re: JP-8 in a diesel [Re: JHZR2]
Joel_MD Offline
Loc: Severna Park, MD
Perhaps he meant when the USAF switched from JP-4 to JP-8? The Air Force had been slowly converting to JP-8 over many years, but the Green Ramp disaster at Pope AFB in 1994 hastened the end of JP-4 for USAF aircraft.
2015 Volvo S60 T5 - dealer fill Castrol
2007 Dodge Ram 2500 6.7L - Amsoil DEO 5W-40
2003 Saab 9-5 Aero clone - Mobil 1 0W-40
#3764695 - 06/18/15 09:05 PM Re: JP-8 in a diesel [Re: Groundhog]
WANG Offline
Loc: North Carolina
https://www.cumminsfiltration.com/html/en/products/fuel/additives/lub_doser_systems.html
There's the easy answer to using JP8 where it was not originally intended
"Sportbikes have evolved from an axe into a scalpel.
Problem is, the average sportbike buyer is more lumberjack than surgeon." -Richard Pollock
#3764879 - 06/19/15 04:09 AM Re: JP-8 in a diesel [Re: WANG]
Shannow Online   content
Loc: Oz
Like all those additive introducing things, I wonder how they meter it.
In my diesel, the return fuel is quite significant, as it seems to polish the fuel through the course of a tank...i.e. each drop of fuel sees the filter a couple of times.
does it dose every time through ?
#3764924 - 06/19/15 06:58 AM Re: JP-8 in a diesel [Re: Groundhog]
WANG Offline
Loc: North Carolina
The lubricity dosers came about when Cummins began providing the powerplants for MRAPs for the US military. Cummins would not warranty the engines to be fueled with JP8 unless these dosers were used. I wonder what the "dope" is that they are administering?
The metering is a good question. Suppose they are somehow modeled after the way additive-introducing coolant filters dose their stuff.
#3769114 - 06/23/15 02:24 PM Re: JP-8 in a diesel [Re: Shannow]
Jetronic Offline
Loc: down in the park
you can dose the tank every time the filler has been opened... corresponding to the amount added. PSA has been doing it for years with their Eolys additive
AR Giulietta 2.0 JTDM-2 -- mix of leftovers (edge, magnatec, helix ultra extra)
#3769672 - 06/24/15 05:07 AM Re: JP-8 in a diesel [Re: Jetronic]
Loc: Oz
You drop a whole filter in your tank at fill up ?
my diesel fill hole is only a couple of inches, while the additive containing filter that is being discussed looks a little bigger than that.
Or do you cut it up and add only a portion of the additive containing filter at a time ?
#3769912 - 06/24/15 10:34 AM Re: JP-8 in a diesel [Re: Groundhog]
ironman_gq Offline
Loc: MN
I think you missed something, the filter goes in line between the tank and the engine and doses the fuel with lubricant as it flows through. The filter gets replaced or recharged on a regular service interval more than likely based on the gallons that have been put through it.
OR you can add lubricant right to the tank every time you fill the vehicle up.
#3770009 - 06/24/15 11:41 AM Re: JP-8 in a diesel [Re: Shannow]
Jetronic Offline
there's a seperate tank with eolys additiven and depending on the amount added to the fuel tank (diesel that is) the eolys tank pumps additive to the fuel tank for a few seconds upon the next start. the eolys additive tank lasts about 100k miles
