Originally Posted By: WA1DH
Time for another update.
My 4 cyl Ford Escort blows better heat faster than the truck right now. It's 20 out today, but I would think I should get more than luke warm heat and 150 on the gauge after 15 miles of hard driving (I even held it just under red line up a hill). I suspected something is still not quite right, and popped the hood at idle. I revved it under the hood, and to my surprise, the UPPER radiator hose sucks flat when I rev it! The bottom one seems fine.
As I said before, the upper hose makes a 'thud' feeling every few seconds while running at idle, and boils when I shut it off. It obviously has air in it, but WHY?
I'm thoroughly confused now. I'm going to pull the thermostat out when it cools down and just run it without one to see if that makes a difference. I boiled it to test it and even drilled the hole in it to help bleeding. My radiator cap is new and the reservoir moves between hot and cold levels as it should.
I've never had these issues with any of my cars before. This is driving me nuts.
The upper hose goes flat? That seems wrong. I know you verified that you have the right rotation--but as a lark, maybe try the wrong rotation one?
