Was starting a Montero (2.6, gas engine) the other day. It had been sitting for about 18 months. I put fresh gas in, check the oil, fresh battery, and it wouldn't start.
I sprayed two quick squirts of starter fluid into the carb (air filter removed), still no go. One more squirt, and then I was able to fire it right up. It seemed to run fine. It started fine after that (no starter fluid needed). I was alone, so the motor wasn't being cranked as the starter fluid was sprayed in.
Last night I was reading around online, and it seems lots of people are of the opinion starter fluid can damage an engine. What are your thoughts/experience on this?
I ask partly because I have another vehicle that's been sitting a while, doesn't seem interested in starting. I had thought to try the same approach, as it worked. But, if it's going to damage the engine, then obviously I don't want to.
Thanks
Thanks
