Originally Posted By: Shaman
Off-topic, but how has the truck been DD-wise. MPG, issues, modifications, etc?
It is my dads. I have had plenty of drive time ,but never driven it long enough to calculate MPG. My dad doesn't keep up with it.
It was EPA rated 15 city 18 Hwy. Most people on the Frontier forums report similar numbers.
It is an old design definitely not designed with fuel economy in mind.
Aside from that it's actually a nice truck to drive even with 255k on it.
The engine has good low ,and mid range power. top end is weak on the VG motors.
This truck was only rated 210hp ,and 246 ft lbs. Not a lot but it makes 90% of that torque at 1500 rpm ,and makes its peak torque at 2800 rpm.
For the mileage issues have been minimal.
At 70k the passenger exhaust manifold ,and knock sensor were replaced under warranty. Both common issues.
Needed a radiator at 170k. The factory unit never leaked but it started running warm , but never over heated. I kept the cooling system serviced ,but I guess something clogged anyway.
I replaced the OEM supercharger at 218k. It never had a failure , but the old unit was getting noisy.
Other than that just routine maintenance. 2 timing belts, frequent transmission drain and fills ,and oil changes. Truck still has original starter ,and alternator.
