As my luck have it I found a Kitchenaid Artisan Mixer (no bowl or accessories but otherwise complete) in a dumpster, and have managed to return it to working condition with a little work. I plan on using the mixer in the kitchen for food preparation.
http://www.kitchenaid.com/shop/countertop-appliances-1/countertop-appliances-2/stand-mixers-3/-[KSM150PSER]-400120/KSM150PSER/
I can hear the gears are running a bit rough so I might do a detail strip to check on the nylon worm gear, and since I have it open I might as well replace the grease if there are issues.
Here is a video I found of the strip down, you can see how the grease are packed. Accroding to Kitchenaid, unit is "lubricated for life":
http://www.youtube.com/watch?v=VeCiivPt7hk
I've done some research on the grease they use. Here are my findings:
OEM grease are available for about $16 here:
http://www.seneca-river-trading.com/4176597.html#.UuXjLXn0BO0
I read here that said OEM grease is Shell Darina #2 grease, about $6 for a cartridge:
http://www.fixya.com/support/t7798016-type_grease
http://www.pdblowers.com/pr93-shell-gadus-grease---tube.php
I am not a fanboi but AMSoil also have a H1 food grade grease, about $10:
http://www.amsoil.com/shop/by-product/grease/x-treme-synthetic-food-grade-grease/?page=%2fstorefront%2fgxc.aspx
Finally, I have several tubes of Synco Super-Lube Synthetic grease on-hand, H1 food grade, about $4 from Habour Freight:
http://www.super-lube.com/synthetic-multipurpose-grease-ezp-49.html
Ideally, I would like to use the Super-Lube grease I have on-hand, since I don't have to pay shipping. Do you think it is suitable for the application? Also should I just apply only a small amount or should I pack the whole gear assembly factory style as seen in the video?
The unit is well built and with correct maintenance I think can last a long time.
