microGreen Memorial Day Sale
by DBMaster
30 minutes 29 seconds ago
Biomed Tech internship - Osceola, FL
by Mr Nice
42 minutes 41 seconds ago
New Car - First OCI Subaru Outback
by Oldswagon
Today at 02:43 PM
using many cans of crc intake cleaner good?
by ziggy
Today at 02:37 PM
Mazda's RX Vision with rotary engine won't happen
by HTSS_TR
Today at 01:45 PM
Oil shearing vs fuel dilution
by Popsy
Today at 01:31 PM
Told SiriusXM to Pound Sand
by Garak
Today at 01:22 PM
CB install '98 F250ld
by asand1
Today at 12:53 PM
Kohler K532 Engine John Deere 400
by Bighorn2500
Today at 12:41 PM
Champion C165 cut open, 9000km
by turboseize
Today at 12:30 PM
F1 - 2016 Monaco Grand Prix
by gofast182
Today at 11:39 AM
Mazda 3 drain and fill
by jay929
Today at 11:38 AM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
82 registered (2010Civic, another Todd, 2009Edge, 97f150, asand1, 7 invisible), 1979 Guests and 352 Spiders online.
57973 Members
66 Forums
249394 Topics
Page 3 of 5 < 1 2 3 4 5 >
#3301919 - 03/05/14 02:53 AM Re: The confusion around BMW M oils continues [Re: Clevy]
Leonardo629 Offline
Loc: So. Cal
A can of MoS2 is around $5.60 plus tax where I live, and I have a little stash of it. I don't know about running Ceratec in my M3, but so far I notice no ill effect with MoS2 and my car is not burning oil even though I occasionally rev my car to 8600RPM.
Originally Posted By: Clevy
Mos2 is great stuff man.
Try ceratec. Its like mos2 but uses ceramic nano particles or something. It last for 30000 miles between treatments too however I'm using it every second oil change. I've got a stash.
Edited by Leonardo629 (03/05/14 02:55 AM)
2013 E92 M3 --> M1 0W40
#3302126 - 03/05/14 10:02 AM Re: The confusion around BMW M oils continues [Re: brian_fantana]
dparm Offline
Loc: Chicago, IL
Originally Posted By: brian_fantana
Just realized who I was talking to.... Your on every oil post on the m3 forum. Given my situation what would you do if you were in my shoes. Planning to have a blackstone report done with this oil change to see how I'm doing, but I really don't beat my ride. I'm on the freeway the majority of the time with the cruise set. I would think the oil burning occurs pre operating temp no?
I'd run the M1 0w40 without hesitation.
Are you positive the oil is burning and it's not leaking?
2011 BMW M3 sedan ZCP
#3302698 - 03/05/14 08:21 PM Re: The confusion around BMW M oils continues [Re: dparm]
brian_fantana Offline
Loc: WA
Yes positive. Its garaged so I would spot if I was leaking, plus the smell is extremely distinct. I have been using the service warning as to when it's time to change. I'm not even sure what the intervals are between changes. My ignorance is kind of embarrassing. From what I have read it's very common to go 5k I think. A habit I'll probably adopt.
I did see some guys posting saying they were going through 1 qt every 2-3k. I'm doing a qt like every 6 months. Leonardo629 (another huge m3 poster) has me tempted to try that additive he's using.
'09 E90 M3 DCT
Castrol Edge 10w60
#3303061 - 03/06/14 08:01 AM Re: The confusion around BMW M oils continues [Re: dparm]
dparm Offline
Loc: Chicago, IL
The factory interval is 15k, or whenever the car tells you to change it.
Most guys opt to split the difference and change it every 7-8k. I would certainly keep an eye on that consumption. If it is consistently drinking that much oil you are probably okay, but if the rate is going up then you should be investigating.
#3303213 - 03/06/14 10:20 AM Re: The confusion around BMW M oils continues [Re: brian_fantana]
BMWTurboDzl Offline
Loc: Atlanta,GA
Personally I think type of break-in has much to do with regards to oil consumption. Pity BMW doesn't do a break-in for the engine at the factory.
'15 435i - BMW branded Shell 5w30.
Prev
'10 335d
'06 330i
'03 330i
#3303357 - 03/06/14 01:03 PM Re: The confusion around BMW M oils continues [Re: dparm]
Leonardo629 Offline
Loc: So. Cal
I didn't want to mention break-in procedures because it's a can of worm that needn't be opened.
I have been in the "hard" break-in camp since my younger motorcycle days, so of course I couldn't shake the old habit even when it comes to cars.
I really can't tell you if it's the MoS2 or my break-in method, but my S65 is not burning oil (I have around 4000mi accumulated on the M1 0W40, will change at @ 5000mi and an UOA).
High revving M motors are equipped with low tension piston rings according to a quote I read by a M engineer, so it's normal to burn some oil, did you check your oil cap? BMW oil caps do not seal for the amount we pay for these M cars.
#3303362 - 03/06/14 01:10 PM Re: The confusion around BMW M oils continues [Re: dparm]
dparm Offline
Loc: Chicago, IL
BMW M engines have the 1200 mile break-in period. Special oil and redline is severely reduced. Most modern motors come broken-in anyway.
Not sure why there's an expectation that a car should burn zero oil. As long as it is drinking it at a reasonable and consistent rate, keep on driving it and enjoying it.
#3303677 - 03/06/14 06:44 PM Re: The confusion around BMW M oils continues [Re: dparm]
vinu_neuro Offline
Loc: Chicago / IN
It is the opposite. 95-97% of engines aren't fired at the factory. They are only cold tested.
04 Honda Accord Coupe V6 6MT | M1 EP 0W-20
#3304347 - 03/07/14 10:35 AM Re: The confusion around BMW M oils continues [Re: vinu_neuro]
dparm Offline
Loc: Chicago, IL
I oversimplified. Modern engines are built with very good tolerances and didn't have the variation you used to see 40+ years ago. The notion of break-in is not what it used to be.
I know for a fact that BMW does put all their cars on the dyno before they leave the factory.
#3304401 - 03/07/14 11:46 AM Re: The confusion around BMW M oils continues [Re: dparm]
BMWTurboDzl Offline
Loc: Atlanta,GA
+1, but they're not cycles under different loads from what I understand.
Prev
'10 335d
'06 330i
'03 330i
#3308987 - 03/12/14 04:06 AM Re: The confusion around BMW M oils continues [Re: dparm]
Olas Offline
Loc: Manchester, England
BMW's confusing and self-contradictory statements regarding oil for M motors comes down to two things;
1 - A way to wriggle out of repairs under warranty, chances are the car did not follow the reccomendations every time they were changed,
and
2 - The prevalence of the internet means that you guys in the US can pick up a TSB that was meant for the colds of Northern Europe (or some other geographical crossed lines leading to misinterpretation)
Bottom line?
Redline or Millers.
/thread.
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3330822 - 04/01/14 09:26 PM Re: The confusion around BMW M oils continues [Re: dparm]
SilverC6 Offline
Loc: Southeast
Well I'm even more confused now.
The dealer just performed the 1200 mile service on my M6.
I requested Castrol 0W-40 be used but the dealer advised that, indeed, BMW 5W-30 was the proper fill.
Owner's manual clearly states 0W-30 or 0w-40 is approved with 5W-30 and 5W-40 also being acceptable.
I plan to run the 5W-30 for 5000 miles and then change with Castrol 0W-40 myself.
Even with uber LL-01 Euro spec oil, I can't say I believe in BMW's 10K OCI for this vehicle.
'04 Mazda RX8 5W30 Valv Synpwr
'10 &'11 Camry 5W-20 PU
'11 Landcruiser 5W20 PU
'13 BMW 550IX BMW 5W30
'08 BMW Z4M Coupe TWS 10W60
'13 BMW M6 BMW 5W30
#3330878 - 04/01/14 10:09 PM Re: The confusion around BMW M oils continues [Re: SilverC6]
edyvw Offline
Loc: Colorado Springs
It is not only BMW, all manufacturers are saving on oil since they are performing "free" oil changes (free means you will come later once carbon builds up etc).
Go check my UOA on M1 0W40. After 5K TBN was at 2.6!
13' BMW X5 35d (M1 5W30 ESP + OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+OEM filter)
#3331224 - 04/02/14 09:32 AM Re: The confusion around BMW M oils continues [Re: Olas]
dparm Offline
Loc: Chicago, IL
and
Bottom line?
Redline or Millers.
/thread.
If you read the links to the M3 discussion forum I posted, it is actually a matter of BMW NA making a different recommendation than BMW corporate. The memo saying LL01 is okay was only for North America. Everywhere else, you have to keep using TWS.
#3331226 - 04/02/14 09:33 AM Re: The confusion around BMW M oils continues [Re: SilverC6]
dparm Offline
Loc: Chicago, IL
The manual probably says 0w30, 0w40, 5w30, and 5w40 are acceptable for top-ups. Mine says that.
10k might not be so bad, actually. Remember that the car has a huge sump and a large filter. There are a lot of M cars that did the 15k intervals without any major problems. Mine did.
