Hi guys,
I have a 6G74 Mitsubishi motor with about 115K miles and the valve stem seals are leaking.
Extended idle + throttle causes smoke.
Using about 1 quart of oil per 1,500 miles (around 400ml per 1,000km).
I've been researching some DIY seal replacement and it seems like a job I'd be willing to tackle.
My questions:
1. Does this cause any issues other than the inconvenience of filling up the oil periodically?
In terms of either worse fuel economy, damage to any part of the motor or any loss of power?
2. I was told that the valves are likely covered in varnish and replacing the seals without cleaning the valve stems is pointless. Is this true?
As I am only going to do this as a "heads left on" job.
3. From the service history of the car, Castrol Magnatec oil was used, and I've read this is likely the cause of the valve seal leak. Does this sound correct?
4. How fast will the valve seals deteriorate?
Help is appreciated
My questions:
Help is appreciated
