My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
80 registered (Abdulla, 09_GXP, bdcardinal, AandPDan, bbhero, barkingspider, 8 invisible), 2005 Guests and 9 Spiders online.
58578 Members
66 Forums
252193 Topics
Page 1 of 2 1 2 >
#3256192 - 01/22/14 12:19 PM CHF 11S or 202 in GM R&P system?
Falcon_LS Offline
Loc: Kuwait
I'm looking to run synthetic PSF in my Envoy and don't have much choice in my neck of the woods. I'm wondering how compatible Pentosin's CHF 11S or 202 fluid would be with my rack and pinion set up? Thanks!
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#3256197 - 01/22/14 12:22 PM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
dparm Offline
Loc: Chicago, IL
What is spec'd for that vehicle? CHF11S and the newer 202 are general-purpose hydrualic fluids, and are very stout.
2011 BMW M3 sedan ZCP
#3256282 - 01/22/14 01:17 PM Re: CHF 11S or 202 in GM R&P system? [Re: dparm]
BISCUT Offline
Loc: NewYorkistan
And pricey 2! Get what you pay for. I recently did a power steering flush and reservoir swap (filter in-bedded) with CHF11S.
2015 F150 Lariat M1 0-20 FRAM ULTRA (12k)
2007 Maxima M1 5-30 FRAM ULTRA (113k)
#3256308 - 01/22/14 01:36 PM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
EricF Offline
Loc: SF Bay Area
Maybe an addtive would be easier to find? like LubeGard's p/s protectant, or maybe ATP's p/s protectant?
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#3256408 - 01/22/14 02:54 PM Re: CHF 11S or 202 in GM R&P system? [Re: BISCUT]
dparm Offline
Loc: Chicago, IL
Yeah, but it's a great fluid. You can get it at Pep Boys, O'Reilly, etc with coupons.
#3256523 - 01/22/14 05:03 PM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
SHOZ Offline
Loc: Illinois
Synthetic ATF? It's easy to get.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#3256593 - 01/22/14 06:20 PM Re: CHF 11S or 202 in GM R&P system? [Re: dparm]
BISCUT Offline
Loc: NewYorkistan
I didn't notice it around me...I had to go Amazon route. I'l keep this in mind next time. Thanks for the heads up.
#3257858 - 01/23/14 07:24 PM Re: CHF 11S or 202 in GM R&P system? [Re: dparm]
dailydriver Offline
Loc: Bucks County, Pa.
NAPA as well.
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3257862 - 01/23/14 07:26 PM Re: CHF 11S or 202 in GM R&P system? [Re: dparm]
dailydriver Offline
I thought that the 11s was the better/newer/updated fluid.
It has better specs on paper according to their site's PDSes on both?? ???
BTW; I also would like to know if it is compatible/usable in a DOMESTIC GM (vs. euro Opel/Vauxhall) power steering system (seal compatibility/etc.).
M1-206 oil filter
#3259219 - 01/25/14 02:49 AM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
The unit is spec'd for GM Power Steering Fluid, and the part number listed in the manual is 89021184.
I won't run ATF in a modern GM steering system. After researching this quite a bit, it was actually on BITOG that I found out GM's PSF is a mineral fluid with a boron and phosphorous additives.
The last time I flushed out the system in February '13, and I've put about ~16,250 miles on it since. The steering started feeling a bit numb, so I thought I might as well change the fluid. When I disconnected the return hose going to the cooler and saw the stuff coming out, I wasn't happy to say the least. I went through 2 quart bottles of GM's PSF, but I'm going to be repeating it later on today to flush out the old stuff.
Given the condition of the fluid, I would like to switch to synthetic. I have little to no choice of product for an alternative, however. You get the OE fluids, like Honda's and GM's and so forth, but nothing in the aftermarket.
Pentosin and Febi-Bilstein have CHF 11S, 202 and 7.1 available in German parts stores and last I checked, 11S was a superior fluid to 202. I haven't looked into 7.1 though.
#3259661 - 01/25/14 01:18 PM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
Alright, so I took the plunge and made the switch. Went through 3 liters - 2 to flush and 1 to fill.
Nothing much to write home about, other than the steering feels slightly firmer. Feels like there's less “drag” on the engine, but that could just be my imagination. Let's see how it holds up.
#3260249 - 01/26/14 04:57 AM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I believe the 202 is the newer stuff. 7.1 should be older, mineral based. The Pentosin site (or Beck Arnley site, which has a bunch of Pentosin information) might have some idea as to compatibility.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3260342 - 01/26/14 08:14 AM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
SHOZ Offline
Loc: Illinois
202 is synthetic.
Pentosin CHF 202 Long-Life Synthetic Hydraulic Fluid For Modern Vehicles
Approvals/Specifications
Organization Name Specification Met
DIN 51 524 T3
Ford Ford approved
GM/Opel B 040 2012
Hyundai 00232-19017
ISO 7308
Porsche 000 043 206 56
Volkswagen TL 52 146.01
Volvo 30741424
#3260786 - 01/26/14 05:23 PM Re: CHF 11S or 202 in GM R&P system? [Re: Falcon_LS]
dailydriver Offline
^^^THIS is what I thought as well, at least according to their own spec sheets (and looking at those specs it HAS TO BE a full synthetic wink ). ???
My local semi-indie store in Lambertville has this stuff (the 11S) right on the shelf for $21.35
M1-206 oil filter
#3261281 - 01/27/14 07:35 AM Re: CHF 11S or 202 in GM R&P system? [Re: SHOZ]
Whitewolf Online   content
Loc: MI, USA
CHF 202 is PAO/HC
CHF 11S is PAO
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
Page 1 of 2 1 2 >
