2015 Silverado - Put some chrome
by Realtech214
05/02/16 10:22 PM
Ticks!
by spasm3
05/02/16 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
05/02/16 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
05/02/16 09:20 PM
Purolator Boss PBL25277
by Quattro Pete
05/02/16 09:11 PM
Pan w/ drain plug for 62TE
by JTK
05/02/16 09:04 PM
2007 Explorer 4.0 upper and lower intake gaskets.
by ls1mike
05/02/16 08:55 PM
Cars... where they belong: On the road!!!
by Spillips
05/02/16 08:29 PM
I got 'spoofed' !
by Geauxtiger
05/02/16 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
05/02/16 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
05/02/16 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
05/02/16 07:02 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
24 registered (Dykkerdahl, EchoTech1945, 01_celica_gt, ajchien, carlprop, Atesz792, 1 invisible), 629 Guests and 321 Spiders online.
57779 Members
66 Forums
248388 Topics
Page 1 of 2 1 2 >
#3256341 - 01/22/14 02:06 PM PYB Question
Since1941 Offline
Loc: Hawaii/Ohio USA
Hey everyone,
I have a question? I have a 2009 Rubicon Unlimited Wrangler with the 3.8L. It only has 30k miles on it, and is still under warranty. I also bought the extended Chrysler warranty. Anyhow, I did an oil change with Mobil 1 forgetting it didn't meet the Chrysler spec. I was looking at conventional oil, as it is cheaper, and I do not do any extreme driving.
So, would PYB do a good job of keeping my engine clean? I know it is an outstanding oil, and I know Mobil 1 is, too. I chose synthetic for cleaning, wear, and cold weather properties. It has been in the - degree temps here in Ohio.
Anyways, I was just looking for some feedback on using this oil. I was also looking at the new Castrol Titanium 5w20 since it is a thicker 5w20. I know it is not a huge difference, but with these 3.8L engines, I thought it might be beneficial.
I appreciate any input, and taking the time to read. I am looking to use a Fram Ultra.
2009 Jeep Wrangler Unlimited Rubicon 3.8L
2012 Jeep Wrangler Unlimited 3.6L
#3256348 - 01/22/14 02:10 PM Re: PYB Question [Re: Since1941]
10cent Offline
Loc: Raleigh NC
PYB is a fine oil and will work well in your application. Chrysler seems to love Pennzoil and every Jeep dealer in my area uses Pennzoil conventional as their bulk oil so I'd imagine there are thousands of 3.8's living happy lives with it.
2011 BMW 328i
Mobil 1 0w40
2015 Wrangler Unlimited
Valvoline 5w20
#3256363 - 01/22/14 02:21 PM Re: PYB Question [Re: Since1941]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Pay not attention to moronic advertising claims on the bottle UNLESS they are Manufactures approvals and service categories.
Ad copy - they hold no water whatsoever.
"40% Cleaner than running coal tar" - what a joke.
There is an ILSAC GF5 spec. There are ACEA specs.
Is the chrylser non-turbo spec just a regurgitation of API SN/ ILSAC GF-5? Dont dump the Mobil for a silly reason like that.
Edited by ARCOgraphite (01/22/14 02:24 PM)
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3256404 - 01/22/14 02:52 PM Re: PYB Question [Re: Since1941]
Since1941 Offline
I'm not dumping the Mobil until the time comes for a change. However, I was just looking at when time is due, switching to something approved.
#3256419 - 01/22/14 03:01 PM Re: PYB Question [Re: Since1941]
Miller88 Offline
Loc: Onondaga County
I wouldn't run any expensive oil in a 3.8 - especially with the way the burn through it. Replacing $6/QT M1 every 600 miles is a lot more expensive than replacing $3/QT PYB every 500 miles.
PYB should work well. It's not a "high tech" engine that requires a synthetic.
Though, I'd buy some 5w-30 and cook the record books so it looks like you bought and used 5w-20.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3256440 - 01/22/14 03:16 PM Re: PYB Question [Re: Since1941]
dlundblad Offline
Loc: Midwest
You bought an extended warranty? Ours (2009) came with a lifetime drivetrain warranty from the factory and will be in affect until we sell it. It covers the lockers, transmission etc even if we wheel it.
I bought some Pennzoil Ultra to use in the Fords 6.2 and the Jeeps 3.8 (it meets both specs) but I think I'll give PYB a try next time. Current fill is M1 5w20.. And I have some 5w30 to burn through as well. No pun intended.
2003 Jeep Grand Cherokee / 4.0 / 180k
PYB 10w40 w/ 16% 5w20 / Fram TG16
2002 Volvo S60/ 2.4t / 150k
Mobil 1 0w40 / Mahle OX 149 D
#3256445 - 01/22/14 03:29 PM Re: PYB Question [Re: dlundblad]
Since1941 Offline
I bought the extended warranty because my brother works for Chrysler, and it was over half off. Otherwise, I would have not.
#3256471 - 01/22/14 03:54 PM Re: PYB Question [Re: dlundblad]
Miller88 Offline
Early 2009 came with the lifetime powertrane warranty. It was cut off a ways into 2009 from what I understand.
#3256487 - 01/22/14 04:05 PM Re: PYB Question [Re: Since1941]
Clevy Offline
Loc: Saskatoon canada
Iirc PYB is the factory fill from Chrysler is it not? And the SRT vehicles get a specially brewed version of pennzoil ultra don't they?
The only reason that Mobil doesn't have the approval stamp from Chrysler is a few years ago there was a bit a of falling out and Chrysler then went to pennzoil to formulate the SRT oil. Prior to that M1 0w-40 was the oil specified for the SRT engines and I think was the factory fill so don't look to deeply into M1 not having formal approval.
I seriously doubt M1 useage will lead to any lubrication problems nor will using it cause any potential warranty concerns.
But you can't go wrong with PYB. Its a great conventional oil and will easily run a 5000 mile interval in a properly maintained engine.
As far as cleaning goes pennzoil makes some rather large claims and they've done some significant testing to prove their results however as with all advertising take it with a grain of salt.
We've seen pics of engines running various conventionals that were spotless under the valve cover so I think its less due to the oil and more due to the maintenance plan so keep that in mind.
If you run your engine hard or lots of short tripping where oil doesn't maintain operating temp for long or lots of city miles,basically what we call severe service then the interval should be shortened somewhat or use a synthetic and run it longer.
However you go about it,whether synthetic or conventional consider your driving habits then choose the oil that best fits the service schedule you prefer and go from there.
The 3.8 isn't high tech, it is a torquey,low rev tractor motor that will last nearly forever if maintained properly.
2006 Charger RT
Miles x 2 per oil filter
#3256512 - 01/22/14 04:38 PM Re: PYB Question [Re: Since1941]
NHGUY Offline
Loc: USA
The 3.8 started life as the old pushrod Chrysler 3.3 with a longer stroke.3.8s seem to wear far faster than 3.3s and burn way more oil.Chrysler's first V6 FWD engine (minivans/larger FWD cars).
#3256563 - 01/22/14 05:51 PM Re: PYB Question [Re: NHGUY]
Since1941 Offline
I do not know the schematics of this motor. I was always a 4.0 guy when it came to Jeeps. However, I do know a few people with very high miles on their JK 3.8L motors, and no problems at all; including oil burning. But, I have heard of the oil consumption issue.
I am just trying to find a happy medium with taking care of this thing.
#3256619 - 01/22/14 06:53 PM Re: PYB Question [Re: Since1941]
jamesyarbrough Offline
Loc: Denison TX
Pennzoil looks amazing on paper. I think I would choose the PYB and maybe QSGB would be my second choice.
2006 F-150 M1 0w40 & Bosch
2004 Explorer M1HM 5w30 & Bosch
1986 Lincoln SA200 T6 5w40 & Wix
#3257747 - 01/23/14 05:19 PM Re: PYB Question [Re: ARCOgraphite]
dave1251 Offline
Loc: Maricopa, AZ
I believe you just posted some incorrect information. Mobil One still does not meet Chrysler's specs according to the Mobil website.
That being said I doubt if there was warranty work to be done a warrant claim would be denied.
don't use.
#3261477 - 01/27/14 11:51 AM Re: PYB Question [Re: Since1941]
Loc: N.H, U.S.A.
I was asking a question. Does the Chrysler spec mirror the ILSAC gf5.
Another thread to nowwhere whith no resolution.
#3261547 - 01/27/14 01:17 PM Re: PYB Question [Re: Since1941]
cp3 Offline
Loc: Kitchener, Ontario, Canada
It is basically GF-5 with a 100000 mile fleet test. See here for details.
Dodge Charger|Pennzoil Platinum 5w20|Mopar MO-744
Pontiac G6 GT|Mobil 1 0w40|Mobil 1 M1-101
Page 1 of 2 1 2 >
