Static electricity accumulation of earth and human
by yvon_la
05/30/16 07:26 AM
18.14F this morning....
by Shannow
05/30/16 06:09 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
61 registered (74DartSport, BobS, 3800Series, 94astro, bigt61, Atesz792, 3 invisible), 1073 Guests and 260 Spiders online.
58019 Members
66 Forums
249586 Topics
Page 2 of 2 < 1 2
#3236831 - 01/04/14 08:09 AM Re: 1MZFE 187,500 Miles [Re: Big Smoke]
kschachn Offline
Loc: Upper Midwest
Well, you hit all the high spots in maintaining that engine. Those Aisin kits are awesome. Completely OEM parts for a Toyota and a good price too. Aisin isn't the OEM water pump supplier for my Accord, but I bought one of the kits anyway based on my past experience. It was of very high quality, everything made in Japan.
And yes those spark plug wires are ready to install which makes it easy.
Originally Posted By: Big Smoke
I did a laundry list of things that totaled up to about $1,200. TB kit, plugs, wires, all cooling hoses, t-stat, rad cap, valve cover gaskets, pcv, pcv grommet, cam seals, crank seal, A/C & P/S belts, fuel filter, and quick struts. Most all my parts were OEM. Amazon has a great price on an OEM Aisin TB kit (TKT-024) which includes the hydraulic tensioner and idler bearings. All the other OEM stuff came from a dealer in VA and it didn't add that much to the cost vs. aftermarket items. The nicest thing was the plug wires that came already loomed.
Now hopefully all I need to do in the next 112,000 miles is change oil and filters.
I have an OEM set of heater hoses (engine to heater coil) if anyone is interested. PM me.
1994 BMW 530i, 205K
1996 Honda Accord, 216K
1999 Toyota Sienna, 344K
2000 Toyota ECHO, 252K
#3238563 - 01/05/14 05:08 PM Re: 1MZFE 187,500 Miles [Re: Big Smoke]
mr_diy Offline
Loc: Michigan
Originally Posted By: renegade_987
Looks excellent for an almost 200K motor
Thank you. 3-4k OCI's, regular PCV changes, air filter changes, and TB kit every 90K (+/-). Ready to run to 300k before the next heavy maintenance. Also did the KYB quick struts all the way around. Very happy that I went with KYB, what a nice firm ride.
Has your TB looked worn at 90k? I have been going by the original owners manual supplement that only calls for a TB replacement, at 90k, for "heavy commercial use". Otherwise no apparent replacement recommended. I plan to only replace when the water pump needs replacement.
98 Toyota Sienna 155k, 18-26mpg, 21avg
13 Honda Civic 12k, 28-45mpg, 34avg
#3238568 - 01/05/14 05:16 PM Re: 1MZFE 187,500 Miles [Re: renegade_987]
javacontour Offline
Loc: Illinois
The supposed sludge monster V6.
Yes it would sludge. But I suspect only if you pushed OCI to the limits or beyond.
Nice job!
network down, IP packets delivered via UPS -BOFH
#3238716 - 01/05/14 08:00 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
Big Smoke Offline
Loc: Knoxville, TN
It has looked great both times. First one was done right at 90k and the second one at 187K. I plan on going 112k on this one. The valve covers and cam seals needed done badly. That was the main reason for this TB job.
1999 Camry XLE - 253,000 Miles.
#3238756 - 01/05/14 08:35 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
kschachn Offline
Loc: Upper Midwest
You're going to wait for a water pump failure? That's one component I'd rather not wait till it fails.
The belt itself usually looks pristine at changeout. However, the idler and tensioner pulleys will fail before the belt.
1994 BMW 530i, 205K
#3249919 - 01/16/14 06:04 AM Re: 1MZFE 187,500 Miles [Re: kschachn]
mr_diy Offline
Loc: Michigan
Thanks for the info. What time or mileage is your experience on idler/pulley replacement?
#3256491 - 01/22/14 04:10 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
Big Smoke Offline
Loc: Knoxville, TN
A complete OEM kit (Aisin) can be had for $140. Why not just buy the kit and replace at every TB change? It's cheap insurance.
#3256627 - 01/22/14 06:57 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
kschachn Offline
Loc: Upper Midwest
Well, the one time I didn't change the idler and pulley with the belt (the first change) it failed about 20,000 miles later. The engine started making a knocking noise at a certain RPM, almost like rod knock (the pulleys are bolted directly to the head and/or block). The dealer in town diagnosed it for free for me when I had it in for something else. The tech pulled back the timing cover and as the engine was revved, you could see the idler "hop" or wobble when it made the noise. He said it was common if you didn't replace the pulleys at the same time as the belt smile
And I agree with the comment about buying the Aisin kit and putting it all in. You can't go wrong with that kit.
1994 BMW 530i, 205K
Page 2 of 2 < 1 2
