Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
20 minutes 44 seconds ago
new Tundra color
by lawnman
23 minutes 5 seconds ago
Bought A Yamaha XSR900 today!
by donnyj08
38 minutes 10 seconds ago
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
50 minutes 30 seconds ago
Replace oxygen sensor by mileage ?
by Merkava_4
57 minutes 11 seconds ago
I was slightly wrong on the Purolator transition
by slacktide_bitog
Today at 09:57 PM
Things your dogs have eaten.....
by OVERKILL
Today at 09:45 PM
What Happened To Johnny ??
by crazyoildude
Today at 09:39 PM
Home Depot--Formula Shell--Buy 4 qt. get one free.
by BigD1
Today at 09:34 PM
Varnish in engine
by paulri
Today at 09:23 PM
Lubrication Engineers 75w90
by Hullthumper
Today at 09:19 PM
Get the legless guy a cup of tea.
by Shannow
Today at 08:53 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
78 registered (01rangerxl, 97K15004WD, 901Memphis, aquariuscsm, 92saturnsl2, 8 invisible), 1464 Guests and 13 Spiders online.
58341 Members
66 Forums
251126 Topics
Page 1 of 2 1 2 >
#3256233 - 01/22/14 12:44 PM 0w-30 Mobile1
Mach1Owner Offline
Loc: PA
I'm thinking of making this my usual change for my 2014 Altima. Nissan recommends both 0w-20 and 5w-30.
If I understand right 0w is easier for cold start ups, and 30 gives better wear protection than 20. So am I right in assuming that 0w-30 would give the easiest cold start and best protection?
I'll be matching this with a Nissan or perhaps a Motorcraft filter.
Edited by Mach1Owner (01/22/14 12:44 PM)
'14 Altima 2.5 S: K&N Intake, M1 0w-20 w/ Nissan filter
Past: '91 Taurus, '01 ZX2, '00 ZX2 S/R, '03 Mach1
Ask me about Zetecs!
#3256248 - 01/22/14 12:50 PM Re: 0w-30 Mobile1 [Re: Mach1Owner]
dparm Offline
Loc: Chicago, IL
30 does not necessarily give better wear protection. Thicker is not always better. That being said, a 0w30 will work fine in place of a 5w30.
I would use the 0w20 unless the car sees severe usage on a regular basis.
2011 BMW M3 sedan ZCP
#3256251 - 01/22/14 12:51 PM Re: 0w-30 Mobile1 [Re: dparm]
Quattro Pete Offline
Loc: Great Lakes
+1
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3256280 - 01/22/14 01:15 PM Re: 0w-30 Mobile1 [Re: Quattro Pete]
BISCUT Offline
Loc: NewYorkistan
+1
+2 20wt oil with the reasonable OCI has kept my F150 happy!
2015 F150 Lariat M1 0-20 FRAM ULTRA (12k)
2007 Maxima M1 5-30 FRAM ULTRA (113k)
#3256291 - 01/22/14 01:25 PM Re: 0w-30 Mobile1 [Re: Mach1Owner]
Clevy Offline
Loc: Saskatoon canada
Unless you are regularity achieving oil temps above 240ishF there really isn't any need for a thicker oil not that going thicker would really hurt anything though.
Think of it this way. Your engine requires a film of oil on the moving parts. If oils temps aren't high enough to compromise the oils film strength then the parts are separated,and a thicker film of oil will do nothing but increase drag.
You require an oil film and a thicker film gains nothing unless you are seriously heating up the oil and those temps affect the oils film strength.
I'm using a 5w-20 in my hemi. My last hemi was an 04 ram quad cab 4x4. It had 280k on it when I totalled it.
I bought it with service records and the oil was changed by the dealer every 5000 miles with conventional bulk oil.
That truck ran like a top,consumed no oil whatsoever and I couldn't tell a power difference from it vs my dads 2012 ram,so today's 20 grade oils are proven to keep engines running just fine for many hundreds of thousands of miles.
That being said going a grade thicker won't hurt, it is unnecessary though unless you are experiencing sustained elevated oil temps and require a thicker oil to compensate.
2006 Charger RT
Miles x 2 per oil filter
#3256319 - 01/22/14 01:46 PM Re: 0w-30 Mobile1 [Re: Mach1Owner]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Picking the right oil for the engine type and tolerance stack is most important. Some may do well on a 5w20 other swell on a 10w30. Most oil are marginally additised with EP AW so "quality" viscosity may be more important than in the heyday of ton's O'moly and double the phos. Amoung the current ILSAC oils Shell Ultra and BP Edge with Ti are leaders and QSUD and QSGB are the bargains.
Note that acheiving the 0w rating will lead to some healthy performance compromises on a 5 dollar a Litre oil.
Maybe you want to keep a bit of the Ford in play in the Tennessee Renault Altima and run some Kendall GT1 Synthetic! smile if Honda and Ford BOTH trust Conoco-Phillips to make a good OEM branded oil - how bad could it be? Maybe The FORD Synthetic ( also C-P made stuff).
Mobil 1 is just also ran. Mobile 1 is a telephone company(?)
Biggest advice: Stay away from the garbage China-sourced Nissan service replacement Filters -- miles !
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3256347 - 01/22/14 02:09 PM Re: 0w-30 Mobile1 [Re: ARCOgraphite]
SatinSilver Offline
Loc: Ohio
Third largest city in Alabama. laugh
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC filter
#3256407 - 01/22/14 02:53 PM Re: 0w-30 Mobile1 [Re: ARCOgraphite]
OVERKILL Offline
Loc: Ontario, Canada
confused
By this logic M1 0w-40 is a big 'ol batch of compromises too..... Weird how it manages to obtain all those OEM approvals then eh? wink
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3256410 - 01/22/14 02:55 PM Re: 0w-30 Mobile1 [Re: ARCOgraphite]
dparm Offline
Loc: Chicago, IL
I don't think the OEM filters are that awful. How many millions of Nissans have used those and racked up 250k+? Anecdotal evidence for you: my family has owned 4 Infinitis over the last 15 years and they've all been trouble-free after using those "garbage" filters.
#3256447 - 01/22/14 03:33 PM Re: 0w-30 Mobile1 [Re: ARCOgraphite]
Rand Offline
Loc: NE,Ohio
ok I'm going to bite there is so much just plain wrong there but.... how to you determine the ""tolerance stack"" for an engine unless you build it yourself or tear it down and blueprint it?
2015 Forester I-Premium 6MT
#3256481 - 01/22/14 03:59 PM Re: 0w-30 Mobile1 [Re: dparm]
RF Overlord Offline
Loc: Cape Cod, MA
I thought the latest round of NISSAN filters was made in Mexico by Gonher now?
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
#3256541 - 01/22/14 05:30 PM Re: 0w-30 Mobile1 [Re: Mach1Owner]
Garak Offline
Loc: Regina, Saskatchewan, Canada
If you're doing the severe service interval, I'd stick with a 5w-30 conventional. If you're going the longer one, the synthetic 0w-20 would definitely be worth considering. As for a filter, buy by price, within reason. If you can get the Nissan or Motorcrafts at a good price, go for it. I've used the Motorcraft in my G. The best bang for my buck, though, has been the Bosch Premium.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3256573 - 01/22/14 06:02 PM Re: 0w-30 Mobile1 [Re: Mach1Owner]
jamesyarbrough Offline
Loc: Denison TX
Im no expert on the subject, but the way I understand it is that M1 0w30 only has better start up protection in very cold temps and that the 5w30 flavor is actually thinner at mild temps. I also hear that the 0w is thicker at operating temp. But dont take my word for it, im sure one of the experts has better info on the subject.
On the subject of thick vs thin, im a thick guy. Seems like we are the only country in the world who likes thin oil. Same engine overseas is spec'd for a thicker oil (sometimes) so im not buying it. Long as you have good oil pressure though I dont think it matters all that much.
I haven't yet had the chance to try M1 0w30 but I would like to. Im really in love with the M1 0w40 though! It runs very well in my 5w20 spec'd engine with no noticeable negative impact. I even get the same mpg.
2006 F-150 M1 0w40 & Bosch
2004 Explorer M1HM 5w30 & Bosch
1986 Lincoln SA200 T6 5w40 & Wix
#3256583 - 01/22/14 06:10 PM Re: 0w-30 Mobile1 [Re: Mach1Owner]
GMBoy Offline
Loc: Texas
MOBIL.
#3256704 - 01/22/14 07:49 PM Re: 0w-30 Mobile1 [Re: GMBoy]
Loc: Great Lakes
Originally Posted By: GMBoy
MOBIL.
Are you sure???
Page 1 of 2 1 2 >
