Small cars and small overlap front crash test
Great Lakes
http://www.iihs.org/iihs/news/desktopnews/minicars-fall-short-for-small-overlap-frontal-protection
Good (just barely) news for Chevy Spark. Bad news for all others.
In all honesty though, even many larger cars did poorly in this test as they haven't been designed in a way to pass it. I'm sure within a few years the new designs will be introduced that will do well in this test, and the added cost will be passed on to us - the consumers.
And then IIHS will come up with yet another test that nobody can pass so that the insurance companies can hike up your rates "because your car isn't safe."
You said it all.
Since side impacts are safe now we're going to start ramming telegraph poles head-on again?
How about making *them* softer? Ski areas do it!
This size of car class IMHO is a poor value anyway and that is too bad less safe.
The FIT for example did poorly in this test. I really don't see the value of that vehicle vs a Civic which achieves significantly better MPG, larger, better comfort and gets a good rating for the same crash test. The base price difference is $3000.
I don't get these really small cars.
The last paragraph from the article -
"Frontal crash tests like these only indicate how a car will perform in a crash with a similarly-sized vehicle. In real life, however, cars this size are much more likely to hit a larger vehicle, the Institute pointed out. Insurance Institute crash tests have indicated that, in crashes between larger and smaller vehicles, occupants in the smaller vehicle will suffer significantly greater injuries.
"These cars have an inherent safety disadvantage in many kinds of crashes," Insurance Institute spokesman Russ Rader said."
Your choice of words is interesting. Are we designing cars merely to pass the test, or to be safe? If the car is protecting the passengers, it should be able to pass the test...it's not supposed to be the other way around.
Good question. How do we determine if a car is safe? Typically we determine this by looking at how it did in one test or another because this data is readily available.
Sure, you could search for fatality and injury rates instead, but since these accidents happen in uncontrolled environments, you never know if you're comparing apples to apples.
saw this on the morning news, guy said the Fit is a basically a death trap.
How does this relate to past "car-size classes"?
Remember how the Civic now-a-days is larger than an Accord from the past? e.g. - the Fit/Versa were designed to fill the void by the Civic/Sentra as they continued to grow with each redesign.
A Tacoma is much bigger than it used to be. Eventually we'll all be driving tanks.
I'm assuming a 2014 Fit is safer than a 1988 Accord, so at what point is it 'good enough'?
I think the criteria of the test is passenger safety. Nothing else determines the rating I believe.
It is an odd test though, they don't "pad" the barrier to simulate hitting another car.
Overall though, I don't see a big problem with adding additional safety tests. Probably this small offset one isn't even a big challenge to figure out. I imagine at some point they will add air bags on the outside of the car which might cost a little to figure out. But 2 feet of controlled decelleration would go along way to reduce the structural requirements of the actual car to be safe and may even save money?
when there is no more inherit conflict of interest.
case in point: ban all pickup trucks and large SUVs from public highways.
It did below average in the euroNCAP test back in 09 aswell. There are however several good examples of minecars that did well in the euroNCAP.
Renault ZOE and Audi a1 Are Good examples.
I'm not saying the tests aren't necessary. I just don't like the idea that cars are designed to pass the test. A standard is still a necessity to compare vehicle safety.
There have been many vehicles over the years (Volvo, hint hint) that were so safe to begin with that they were passing the tests before they were even required. That is a sign of good engineering and prioritizing safety. I think this philosophy is applicable in many areas of engineering and design.
I agree. But this costs money, so many economy-tier car manufacturers won't go out of their way and over-engineer on safety unless some test makes them look bad.
Then there is the separate issue of the test's validity. Is it really reflective of some real-life scenario and what is the likelihood of its occurrence? Designing cars is about compromises - you can't have it all and still meet a given price point that will assure sufficient demand. So I can't necessarily blame the engineers either.
Everything's a compromise. Mercedes got flamed 20 years ago because their cars didn't crumple "as much" in our 30 mph brick-wall test, and the occupants felt more decelleration than they otherwise would have-- even though they were "safe". Merc pointed out that head-on crashes were often one corner and they were glad to be stiffer.
Did you know seat belts have some stretch built in? This helps in the vast majority of crashes but is a compromise in the super high speed doozie ones.
I think the standard testing makes all the car makers make safety a consideration, otherwise advertising claims could make it hard to figure out which cars are built well and which ones just claim to be.
One of the british car shows did a offset crash of a, "safe" at the time, late 80's Volvo and some new Renault small hatchback. The result was near certain death for people in the Volvo, and the Renault passengers probably walking away...
So I think the standardized testing has been effective in increasing all cars safety, probably more than if the manufacturers had been left alone.
IMO, the value is what you called out, its $3K less. Plus I would think as you incorporate more add ons to the base model, the Civic "feels" more expensive that the Fit.
Not trying to defend the Fit or that size car in general, I just think it is filling that segment of the market that wants to buy new but wants a lower (lowest) price tag, safety may isn't the first thing the consumer.
I wonder how the Versa Note would have performed? I think there are some differences between the Versa sedan and the Versa Note.
