killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
19 registered (bdcardinal, dec219644, Blkstanger, Enumeratum, EchoTech1945, 3 invisible), 575 Guests and 17 Spiders online.
58578 Members
66 Forums
252174 Topics
#3255756 - 01/21/14 10:15 PM Transmission drain
Nick1994 Offline
Loc: Phoenix, AZ
I've decided to do a tranny pan drain on the Camry. It's an automatic and has a drain plug. I've got 3 quarts of Maxlife ATF. How much do you think will drain out of the pan? I'll drain every couple months.
2000 Toyota Camry 2.2L 214k
Mobil 1 EP 10w30 & Fram Ultra
#3255759 - 01/21/14 10:19 PM Re: Transmission drain [Re: Nick1994]
Ramblejam Offline
Loc: Kentucky
I'd expect 2.6 quarts (A140E).
#3255762 - 01/21/14 10:24 PM Re: Transmission drain [Re: Nick1994]
GaleHawkins Offline
Loc: Murray KY USA
I would get 6 quarts if you are going to do it that often. We have GM and I have never got more than 6-7 quarts out of one from the pan. I like to chance the old out and add the new without them mixing so do the Bucket Flush by tapping in to the radiator cooler return line but your method every few months sounds like a good plan.
How much will drain out will depend on how long you let it set and how much higher the front tires are than the rears due to the torque converter holds a lot of ATF and takes time to drain down as much as possible.
#3255968 - 01/22/14 08:05 AM Re: Transmission drain [Re: Nick1994]
Char Baby Offline
Loc: Western NY
Typicaly those Camry's tranny pans didn't hold a lot of ATF. Often after a drain, you'd only get 2.5-3.0 qt of ATF...That's all!
In some of those trannys, the differential is above the tranny and can also be drained. But, the diff is also supplied by the tranny so, drain both if possible, and just refill through the tranny dipstick. smile
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3255977 - 01/22/14 08:18 AM Re: Transmission drain [Re: Nick1994]
Donald Offline
Loc: Upstate NY
The Amsoil website will provide that exact info for your application. Install a Magnefine inline filter also.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
