2012 Cruze Factory Fill Dexron VI 10,333 miles
North Carolina
This is from our 2012 Chevy Cruze 1.4 Turbo. I decided to drain out what I could and refill which was exactly 4qts. It amazed me at the color of the fluid being so dark at only 10k miles, but from what I have been reading it is an anticorrosive additive that GM put in the FF fluid. At least that is what I'm reading from the Cruze forum. Anyway I'm going to drain out and refill a few more times here in the next couple of weeks to get some fresh fluid back in there and get some of the wear metals out. Below is what BlackStone wrote.
Code:
When it comes to the factory fill, we're not surprised by higher wear metals and silicon. Just as an engine goes
through a wear-in process, a transmission does as well and that's probably why we found aluminum reading much
higher than averages. It could be from the torque converter, oil pump, or other aluminum parts wearing in. We should
see aluminum and other wear-in material wash out with each oil change, so we'll look for that next time. The TAN was
fine at 1.4, showing little acidity. Universal averages are based on ~25,000 miles, so try that next.
OIL Factory fill Dexron VI
MILES IN USE 10,333
MILES 10,333
SAMPLE TAKEN 12/22/13 Universal avergs
ALUMINUM 43 14
CHROMIUM 0 0
IRON 41 133
COPPER 89 102
LEAD 2 82
TIN 5 4
MOLYBDENUM 1 1
NICKEL 1 1
MANGANESE 16 4
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 7
BORON 47 76
SILICON 9 23
SODIUM 9 14
CALCIUM 67 126
MAGNESIUM 0 9
PHOSPHORUS 165 268
ZINC 12 70
BARIUM 26 5
SUS VIS 210ºF 45.1 42-45
cSt @ 212ºF 5.75 4.8-7.9
FLASHPOINT ºF 430 >355
Fuel%
Antifreeze% 0
Water% 0
INSOLUBLES TR
TAN 1.4
TBN was blank, I should have taken the 0 out. Sorry. This is the factory fill so I would guess a synthetic blend fluid.
I just D&R'd the FF ATF in my 2011 Cruze 1.4T at 24K.
I did it cold and was able to drain 4 qts. 12 ounces.
Some on the Cruze forum say you can't over/under fill these 6T40's by even a few ounces without causing problems.
So far so good on mine.
Why would GM start using 'anti-corrosion' additives after not doing so since inventing the 'Hydramatic'. The drained fluid was dark but still had a reddish tint and didn't smell burned.
A/T's are one thing GM seems to do right....why mess with it?
All ATF's have metal deactivators and anticorrosion additives.
The tranny is small with less fluid than other trannies so fluid will oxidize sooner.
I recommend you do drain and refills every 30k with a good DexronVI.
