Whatever happened to Meyer's invention?
by OneEyeJack
18 minutes 18 seconds ago
window tinting
by crestwood
19 minutes 59 seconds ago
Quart low after 3100 miles 4.6 ltr modular
by A1O
35 minutes 3 seconds ago
Canadian Tire - Pennzoil Platinum 50% off
by Uregina09
36 minutes 47 seconds ago
Remember This Filter C&P?
by BlueOvalFitter
54 minutes 51 seconds ago
New X Files..
by Warstud
Today at 06:00 PM
Oil change on 2001 civic with some engine noises
by llmercll
Today at 05:17 PM
Valvoline Cerulean
by Ramblejam
Today at 05:14 PM
Highlander timing belt
by Carguy21
Today at 04:53 PM
Saw my old Saturn Wagon in the wild!
by eljefino
Today at 04:23 PM
Went with Primewells
by Eric Smith
Today at 04:06 PM
121R Battery Group Size Alternatives ?
by neilwestlawn
Today at 03:52 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
115 registered (77GrandPrix, afoulk, akela, 2015_PSD, 69GTX, 2009Edge, 12 invisible), 1458 Guests and 214 Spiders online.
56834 Members
66 Forums
244327 Topics
Page 2 of 3 < 1 2 3 >
#3255170 - 01/21/14 02:08 PM Re: The cheap windshield washer fluids [Re: dparm]
IndyIan Offline
Loc: Ontario, Canada
Originally Posted By: dparm
Originally Posted By: Rand
Sounds reasonable. I've noticed it's less of a problem after I've been driving for 15-20 minutes and the interior of the car is warm AND the washer nozzles are hot.
I think heated nozzles are just to thaw the nozzle as the odd time they freeze up after the car has been sitting as the alcohol evaporates out the line. They might even make the alcohol evaporation problem worse on a very cold day.
Any washer fluid hitting a freezing windshield will leave an ice film in my experience. On my deserted sideroad, 30 seconds at 40mph looking through a clear spot will sublimate all the ice and leave a clear windshield. Maybe not a good idea in a urban drive. Then a few minutes of driving will have the whole windshield above freezing and I can spray all I want with out any freezing. Also I will clean my window when I park the car so I don't have to deal with dirt on a cold windshield. Most days after a quick scrape for frost I don't need to spray any fluid at all until the windshield is up to temp.
07 Focus ZXW, 5spd manual, 131km MM F1 5W20
06 CRV, 5 spd auto AWD, 235km
#3255181 - 01/21/14 02:18 PM Re: The cheap windshield washer fluids [Re: dparm]
99Saturn Offline
Loc: NY
I can't remember the last time I have had an issue with the cheap blue stuff - I just use the -20F year round now. 13F right now and no issues on the trip home, it's full of "Super Clean" or something like that from Kmart - saw the same bottles at AAP last week.
#3255197 - 01/21/14 02:32 PM Re: The cheap windshield washer fluids [Re: dparm]
Rolla07 Online   content
Loc: MTL, CANADA
I like using rain x in all seasons except winter..i use cheap blue stuff in winter.
2007 Corolla Red Pearl 134k miles
TGMO 0w20 & Toyota OEM filter
#3255198 - 01/21/14 02:32 PM Re: The cheap windshield washer fluids [Re: dparm]
Deltona_Dave Offline
Loc: Deltona, FL USA
Here in Central Fl, I just use the Green Rain X bug wash. Works good in the "freezing 28 degrees" that we see for 12 hours a month in January. I use it as it gets the bug guts off the windscreen and helps water bead off, so I don't have to use the wipers as much.
D.
Emergency Vehicle Technician Law Enforcement
2013 Hyundai Sonata GLS 2.4
2013 Kia Optima EX 2.4
2012 Mazda3 2.0 SkyActiv
#3255214 - 01/21/14 02:51 PM Re: The cheap windshield washer fluids [Re: Deltona_Dave]
dparm Offline
Loc: Chicago, IL
D.
Okay, but as I had previously mentioned, it gets way colder than that where I live.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3255224 - 01/21/14 02:58 PM Re: The cheap windshield washer fluids [Re: dparm]
mrsilv04 Offline
Loc: Illinois
I'm south of I-80, and I've used nothing but the -20 degree blue stuff (from either W*M or Menards) for several years now.
Two things:
1) I use the -20 stuff year around.
2) I always keep it tightly capped.
No problems here with the blue. I used to buy the -35 purple stuff, but that was years back.
Is is possible that you're still seeing residual effects of the +32 stuff?
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#3255254 - 01/21/14 03:37 PM Re: The cheap windshield washer fluids [Re: dparm]
JDW Offline
Loc: South
I mix mine myself, 50/50
Ford's & Wix filter's Amsoil 5W-30 SS
2014 Wix Master Tech
#3255255 - 01/21/14 03:38 PM Re: The cheap windshield washer fluids [Re: hattaresguy]
SLCraig Offline
Loc: London, ON, Canada
Originally Posted By: hattaresguy
I've never had a problem with the cheap blue stuff.
I use either the cheap blue stuff or sometimes Rain-X and I can get liquid to my windshield in the coldest of temps with either one. It was -25C recently too.
2010 Civic SI sedan 6MT
Total Quartz 9000 | Wix 7356 | Pennzoil MTF
#3255258 - 01/21/14 03:39 PM Re: The cheap windshield washer fluids [Re: mrsilv04]
dparm Offline
Loc: Chicago, IL
Doubtful -- I ran the reservoir dry before filling with the -20.
#3255264 - 01/21/14 03:48 PM Re: The cheap windshield washer fluids [Re: dparm]
itguy08 Online   content
Loc: Central PA
I typically use Rain-X winter in the winter and summer in the summer. It seems to do a good job and not freeze. I hate having a dirty windshield so I use the stuff quite regularly in the winter.
I have had the blue stuff do the ice up routine too. You could also try the Prestone deicer - that should help too.
The only stuff I don't like is whatever the Ford dealer was using last year - it smelled awful as it dried. Solved that by keeping the resivour full. smile
I'm still waiting for someone to do an actual scented washer fluid.
#3255268 - 01/21/14 03:50 PM Re: The cheap windshield washer fluids [Re: itguy08]
Ramblejam Offline
Loc: Kentucky
The Prestone washer fluid (summer) has a citrus scent.
#3255295 - 01/21/14 04:14 PM Re: The cheap windshield washer fluids [Re: dparm]
DemoFly Offline
Loc: Bremerton, WA
Walmart supertech windshield washer fluid is good stuff.
Cleans great, beads the water up and makes it run off the window just like rain-x.
In fact, I purchased rain-x after using supertech and I couldn't tell a difference except for color.
Pushrods, please.
#3255322 - 01/21/14 04:53 PM Re: The cheap windshield washer fluids [Re: dparm]
fdcg27 Offline
Loc: OH
I use the winter blends of either Prestone or Rain-X in our cars over the winter.
These never seem to freeze and I'll even use the washers to clear frost and ice from the windshield, although I will brush off more than a trace of snow.
Lazy, I know.
You can buy either on clearance each spring for cheap.
I'm going to try adding drug store alcohol to the cheap blue stuff just to see how that works. I'm sure that I have some in the garage.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3255329 - 01/21/14 05:00 PM Re: The cheap windshield washer fluids [Re: dparm]
Corvette Owner Offline
Loc: Waldorf, Maryland
I use Rain-X all seasons. It not only melts snow/frost well, but it also puts a protective coating on the windshield that keeps rain and bugs from sticking to the windshield. In a light rain the rain runs off the windshield without using wipers!
Edited by Corvette Owner (01/21/14 05:00 PM)
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#3255426 - 01/21/14 06:12 PM Re: The cheap windshield washer fluids [Re: dparm]
AMC Offline
Loc: South Eastern, CT
I am currently using the Peak -20 blue fluid with success. It cleans great, dries well and never freezes. I get 6 gallons of it for $10 at Bee Jay's wholesale club. I am pretty sure that price makes it "cheap".
I have also had very good luck with GM Opti-kleen washer fluid but it is expensive, $3 per Gallon
2011 Chevy Silverado - PP 5w-30
2010 Ford Focus - WH 5w-20
2014 Yamaha Super Tenere - Delo 5w-40
1oz TCW-3 Per 5 Gallons of Fuel.
