http://www.bockwaterheaters.com/Portals/0/5-Installation_08_06.pdf
page 5 of pdf (39 on page).
Where permitted by code jurisdictions, a domestic water heater may be used as a heat source for hydronic radiant heating in a closed system, provided all generally accepted plumbing practices for closed-loop hydronic heating are used.
they also say:
- Bock water heaters operate at lower temperatures than boilers, using less fuel to heat potable and radiant water.
- Bock water heaters’ high BTU output makes them far more efficient for radiant heating than boilers.
- One unit heats both water and the home for greater economy
- A well-designed hydronic radiant system can reduce fuel use by as much as 40%.
this is for oil,
so far i'm calculating around 50,000 btuh of heat requirement for my home in winter, for 0 deg F outside and 70 inside. why not use a single oil fired hot water heater with a second loop to do the hydronic heat versus a traditional boiler?
they also say:
this is for oil,
