Originally Posted By: paulswagelock
The boat's previous owner probably used regular oil, which is dirtier.
"In simple terms, the difference is that synthetic oils are made using more advanced refining processes, and hence are of a higher purity and quality than the conventional mineral oils."
"Conventional oils also contain much greater amounts of impurities, such as sulfur, reactive and unstable hydrocarbons, and other undesirable contaminants that cannot be completely removed by conventional refining of crude oil."
Even if we look at the deposit control aspect of "dirtiness" (page 12), Mobil 1 comes in 90/100, whereas the semi-synthetic is at 49/100.
So, yes -- conventional is dirtier than synthetic, regardless as to whether or not you're looking at composition or results from actual operation.
The synthetic has more detergent in it and cleans an engine.
"To test the cleaning power of Mobil 1, researchers tested a European performance vehicle and an American vehicle that had been run with conventional oil, then switched to Mobil 1. After 14,000 miles of driving with Mobil 1 at the recommended oil drain interval, the European vehicle returned to near new levels of cleanliness. The American vehicle experienced even greater improvements from Mobil 1. After the equivalent of tens of thousands of miles of sludge build up, the camshaft hold downs were many times cleaner after regular oil change intervals with Mobil 1. The rocker covers were also much cleaner after running Mobil 1."
The definition of "detergent" as used by the Boating Mag author is unknown, but they're still fundamentally correct.
Your buddy's oil likely looks better than yours, again a bet, because he used synthetic all along and thus it never got dirty inside the engine
"Some of the engine tests we run simulate extremely severe conditions. This particular engine test measures oil thickening and piston deposits in simulated high speed driving in very hot weather. Oil temperature reached 150°C for 100 hours. Mobil 1 can help keep your engine cleaner under high temperature conditions.
Reference not only the "deposit control" I quoted early, but "piston cleanliness" (same page 12) as well. Again, the author is correct.
http://www.exxonmobil.com/AP-English/Files/about_who_Mobil1_supersyn_eng.pdf
