There's a lot of nonsense in this thread.
One, that is definitely not an excessive interval unless an OAI shows some sort of specific issue related to the driving patterns. The OLM is calibrated for quality Dino. Use a Dexos labeled oil for extra peace of mind.
Second, the PCM in the engine will automatically pull the spark signal if the oil pressure drops below a certain value, like 6 psi or so. The engine will not run.
Note that rear main seal leaks have not been a problem in our fleet GM V8 vehicles since the introduction of the Vortec series engines LOOOOOONG ago, it just doesn't happen even after 2-300k miles or more...
