Over the past 2 months or so, I get a loud "clunk" every time I shift into reverse or drive. Also, I get the clunk when coasting when I apply throttle again (downshifting). I do not, however, get the clunk under normal accelerating and upshifting conditions. The sound is coming right from the transmission mount location. The other 2 mounts, which are for the engine, are spaced out pretty far from the mount I think is bad, so I don't think either of those 2 are the problem.
I haven't had a chance to listen in the engine bay while someone else engages a gear, maybe I should get around to that... but I did notice that under idle, the motor doesn't move much. I've seen other instances where someone's mounts were shot, and the motor moved around a ton just in the park gear while idling.
