Guys,
I have come into temporary possession of a 2007 Suzuki Reno which has a shaking steering wheel. Shaking gets worse the higher the speed is. One possibility is imbalanced wheels which could be the problem but I think there could be another reason.
I jacked up the front and tried to twist the tire at the 9-3 position. The tie-rod ends are tight, but there seems to be some play in the steering system. I am able to turn the knuckle about 1/8" left to right before it stops. Also the strut turns/twists with it.
I looked at the strut and it mounts to the strut tower with a single cap, unlike the usual 3-4 nuts/bolts that secure it to the tower. Moreover, the strut cap moves up and down with the suspension (see picture), giving it a lot of movement in my opinion which could contribute to the strut twisting and cause shaking at higher speeds.
How do you propose I get this thing resolved inexpensively? We do not have the finances to replace all suspicious parts, so if there are any tests that I can do, please let me know.
Here's the strut type.
Strut cap with car on ground
Gap between tower and cap disappears when car is jacked up. See contact points in the dust.
Thanks guys!
Thanks guys!
