Originally Posted By: Shannow
Originally Posted By: Russell
There is an emergency jump starter QVC was selling at Christmas for about $20. it is about the size of a coke can. Plug in the cig lighter and wait ten minutes. it is supposed to put enough charge in to start the vehicle. Also can be recharged. have no idea if it will work.
Caveats that come to my mind in this situation: Many car models disconnect the cigarette lighter/auxiliary socket from the battery when the key is in the off position, ergo battery won't get the juice.
If your socket is connected to the battery even if the key is in the off position but your battery is really weak from age or has a defect, it may not take a charge enough to get you going.
Trying to crank with a weak battery and with that device plugged in the cigarette lighter socket may actually burn up the car's relatively thin wires to the socket. A fire is a real possibility here.
Great observations. Related question. I have my deltran battery tender concected via my cig lighter which is active (on my BMW) with the key off. Is there any issue there?
Doesn't plug into the lighter, it clips to the battery...
Instructions say to remove withing 10 seconds of the car starting.
I was referring to Russell's reference to the QVC jump starter device that plugs into the cig lighter socket, not the device with the big battery clamps Chris142 mentions at the top of this thread.
