Originally Posted By: 440Magnum
"While the safety agency listed the action as a recall of Tesla Model S vehicles, Tesla said only the adapter needed work and that was being done with an “over-the-air” software update, so there was no need for owners to bring their vehicles into a dealership."
In other words, the final layer of protection is software/firmware and not a guaranteed hardware fix that will put a hard limit the currents in the adaptor and prevent overheating. If the software has a memory leak, overwrites itself, and locks up, what's to prevent the currents from maxing out?
This is not good practice for consumer-grade electrical power electronics, IMO. Kinda scary, in fact.
It depends on how it is done. Since most likely there are already software control in place they can take advantage of that, or the existing software limit is not low enough and can cause overheating (not the software's fault but the system designer's fault for not checking the limit they tell the software to set).
I wouldn't worry so much about the "software" vs "hardware" debate. There are many good software design and bad hardware design as well. Since they already need to have software algorithm for charging, this is the last thing I'm worry about, as they would have ruin much bigger stuff like battery before overheating if they get it wrong.
