ACDelco X66P
by OldEuroCarLover
Today at 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
Today at 12:02 AM
Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
Yesterday at 10:32 PM
Causes of steering wheel shudder
by buck91
Yesterday at 10:14 PM
Brand new Focus ST...
by Striker
Yesterday at 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
Yesterday at 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
Yesterday at 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
Yesterday at 08:35 PM
Tundra steering wheel
by RN89
Yesterday at 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
Yesterday at 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
Yesterday at 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
Yesterday at 07:50 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
52 registered (Astro_Guy, Bighorn2500, Bear, Alex_V, 2015_PSD, beanoil, 5 invisible), 915 Guests and 38 Spiders online.
58926 Members
66 Forums
253568 Topics
#3251304 - 01/17/14 02:48 PM 2013 6.7 F350 Delo 5w40 7500mi
BeerCan Offline
Loc: FL
2016 Ford F150 3.5 EB
2015 Hyundai Genesis 5.0
2012 Hyundai Genesis 3.8
2015 Ford Mustang 2.3 EB
1999 F350 7.3L PSD
#3251505 - 01/17/14 06:42 PM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
clinebarger Offline
Loc: Fort Worth, Texas
Do you do a lot of stop & go driving, Long idle time?
How often are the regen's, DPF regeneration requires extra fuel to be injected in the cylinder that will dilute the oil with fuel
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3251799 - 01/18/14 04:30 AM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
dnewton3 Offline
Loc: Indianapolis, IN
Wear isn't terrible, but the Al uptick is perplexing. Other parameters not bad either.
I don't really know what you'd run a syn at those short OCIs ... The fuel dilution is the issue here; no syn is going to stop that.
This rig accumulates a lot of miles; probably will have 40k in a year's time? Question is this: what kind of service does it see? If it idles a lot, that would explain the dilution from (likely) frequent regens. If this rig hauls loads on open roads often, coming up to temp and staying under load, then I'd worry about a leaking injector.
Edited by dnewton3 (01/18/14 04:34 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3251805 - 01/18/14 05:01 AM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
dustyroads Offline
Loc: upstate NY
I believe this was your first go 'round with the delo (?).... but wow it looks just like lubrication engineers oil used previously (speaking of the add pack).
Maybe the aluminum spike was due to change in oil chemistry (?)
Have you talked to or read about other 6.7 owners having the same fuel dilution issue? If you're working it, seems as though it shouldn't regen too much. So I wonder if it is maybe an injector related problem.
2011 Taurus sel
QSGB 5W20 MC FL500S
#3251941 - 01/18/14 08:59 AM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
BeerCan Offline
Loc: FL
Truck does not idle long. It is used as a DD but I often tow heavy. Regens are sometimes every 100 mile and sometimes every 400 but avg around 150-180. I often use B5-B20 so that contributes to fuel dilution I am sure.
I have now switched to delo 15w-40 to save some cash
I have an appt with the dealer to check the injectors, I will report back with the findings.
What perplexes me about the Al is that Polaris reported my Ecoboost doing the same exact thing
EB UOA
Al shot up on 1 report and then went back down the next. Strange coincidence I hope.
Edited by BeerCan (01/18/14 09:00 AM)
1999 F350 7.3L PSD
