Originally Posted By: gfh77665
Hypothetically, consider two average vehicles, driven in the exact same manner. One has regular UOA's, and maintenance is done exactly by the UOA directives. The other never gets a UOA, but follows the general consensus of OC's with conventionals at 5000, syn blends at 7500 or full syns at 10K.
Would either last longer? Which would have the greater expenses over a long time period, like 10-15 years?
Short answer:
The non UOA vehicle would have somewhat higher expenses, due to not taking the oil to the maximum OCI, and possible depletion of additives resulting in more rapid wear, if the oil was taken beyond its capability.
Long answer:
Assuming that the same oil is used in both cases (to avoid any argument about one oil protecting better than another), I have to agree with Wilhelm_D. Taking an oil to its maximum distance would minimize cost, and wear would only increase if the oil was run too far and depleted of additives.
You can also throw in the discussion of too-frequent oil changes, which by some indicators increases wear.
All in all, a UOA is a great tool to indicate how far you can safely go with your vehicle/engine, driving style, and oil choice, in order to maximize your OCI. It can also give warning of issues with an engine prior to a catastrophic problem, which is why oil testing is performed on many commercial aircraft.
Usually the manufacturer's OCI takes everything into account so the average motorist (who doesn't have the tendencies of a BITOGer) won't have to worry about oil related failures; I would speculate the manufacturer also allows for lesser oils, which is why many can safely go beyond the OCI in the owner's manual with a UOA.
