It could be an exclusive tire to them, just like the Yokohama YK-whatever number it was, that was exclusive to them previously
Yep. And re-badged tires are ones that should usually be avoided.
If it's a "re-badge", then it is a re-badge of what?
Technically, General Altimax Arctic is a re-badge, but nonetheless it is still a solid tire.
Not sure, but it is unlikely that Continental is using their most cutting-edge technology in a private label tire.
Still a bold assumption. Continental doesn't have an ultra cheap tire brand to go to for a mere rebadge. Nothing from General Tire, nor nothing from Gislaved.
The natural comparison is the ExtremeContact DWS. It does have the traction grooves (which it a "cutting edge" technology from Continental) which the DWS has also. It wouldn't surprise me if they used the same rubber compound to cut down costs. But, yes, the DWS should be better in the packed snow/ice, since it looks like the DWS as lower tread to void ratio and more siping. (but that doesn't bother me since I run dedicated snows anyway)
