The gas tank on my latest piece of equipment (pictures & details tomorrow) is not in great shape. No leaks but I drained a lot of rusty colored gas out with a few flakes of rust here and there. I am fixing how the water could get in. Bought a gallon of denatured alcohol and will add that and let it sit a day or two then drain that. I assume it will absorb any remaining water. Then flush with a gallon of fresh gas and then add fresh gas to try and start it.
The gas tank is 30" wide, 18" high and 6" deep (front to back). So pretty much of a vertical tank behind the driver.
When the weather is nice I plan to remove and seal the tank using a POR treatment (etch, clean, seal).
