Unless the can give you the mileage at which they replaced it, then yes.It's a peace of mind issue.You can't tell from the outside all the time. The gasket usually starts to leak but the egr burning through the upper intake manifold is the real issue to worry about and this will not show from the outside if the gasket is good. I would say you have around 60-100k before it burns through. The newer 3800 had a smaller stove pipe but it's still effected by the issue.This will hydro lock the engine and possible if it leaks internal for a long period of time and mixes with the oil then you could end up spinning a bearing.I think the bearing issue has more to do with not changing the lower intake manifold because the leak slowly and right into the lifter valley. I've seen this happen at least three times and I tried to tell people about the issue before it happened to them but as long as a car cranks and sounds like it is running good they don't bother.
There's a stamp on the intake manifold that tells you what year it was manufactured so that will give you a good range. My last one was made in 2007 or 2010, I think, but I installed it in 2012
