Originally Posted By: MolaKule
I have a 5.3L V8 TrailBlazer and the same 4 cylinders are shut down for economic cruise and low power.
I would prefer a "rotating shudown" sequence of cylinder deactivation but my engine rebuilder says it has more to do with engine balancing, and the EC software would have to be more complex.
Interesting discussing.
there would also be more hardware required (only 4 cylinders have the special lifters and hydraulics that keep both valves closed during deactivation with the current systems), and testing showed its just not worth the trouble, at least on the Chrysler and GM v8s.
The only rotating-shutdown system I recall was the (shudder) Cadillac V-8-6-4 from the 80s. Good idea, but the technology was SO not there. That system used big solenoids to pull the fulcrum pins out of the rocker arms, rather than using a little low-current electrically operated valve to divert oil and collapse selected lifters.
edit>
V8's (at least the American-style 90-degree crank variety) have the feature that the 4 cylinders that shut down are two per bank, not one whole bank like a v6. That might help keep everything more uniformly heated in a v8. As SteveSRT8 said, the Chrysler system has been bulletproof *except* for a possible timing chain failure mode unique to whatever programming is used in Challenger 5.7s. At least that's the buzz on the Challenger forums, and there does seem to be at least some correlation. Its never reported on a manual transmission Challenger, which never turns on cylinder deactivation. It also doesn't seem to happen on the Ram, 300, and Charger, but who knows about internet-reported phenomena like this.
