I need to repack a sealed bearing in a suspension strut top mount. The bearing has red colored rubber seals, I'm not sure of the exact type of rubber.
Since this is a low speed application, is there any specific type of grease I should be using that will ideally be safe on the rubber seal, suitable for low speed use, and if it offers any protection from the elements that would be a bonus.
I was looking at redlines CV2 grease but it doesn't mention low speed suitability and also says minimal effect on rubber seals. Is there such a thing as a crease that has no effect on rubber seals, or will it always have some impact.
thanks very much for any suggestions.
