My inline heater core filter....
Ohio
.....not to beat a dead horse and no real brillance here. I used a 5/8 hose repair ends and fine SS screen from a strainer($10 invested). I molded it around a dowel using torch, hammer and vice. I crimped one end and made petals on the other to tuck under the washer. I expanded it inside the repair end using a larger dowel. Teflon taped the threads on the repair end.
I am flushing an older truck and was worried about debris settling in the core. I thought the screen washers might plug quickly with so little surface area. I will pull at 250 miles to check. What could possibly go wrong.....
if it doesn't leak, then no heat. Otherwise you should be OK.
Originally Posted By: Rand
pic dont work you linked to google+ homepage.
Too old to get this stuff. Did this work?
113804863@N04
I grabbed the image link from the page, not sure how long it'll last. I find it much easier to use imgur.com as there is less control/hassle over how your pic is displayed.
Thank you for helping those of us born before fuel injection and PCMs.
http://www.flickr.com/photos/113804863@N04/
Flushed, all new hoses, 2 subsequent drain and fills. This is what it looks like on the third 25 K pull.
I am ordering a spin on filter set up........
That should be 25 MILE pulls. Looking at wix, or donnalson filter bases today.
