Cheap Electric Pressure Washer
by Nick1994
02/12/16 04:30 PM
Trans/Hydraulic Fluid for Old Tractor?
by 333jeffery
02/12/16 04:27 PM
Does air go stale?
by mjoekingz28
02/12/16 04:13 PM
RAILROAD GUYS: What is this sound and one other Q
by SumpChump
02/12/16 03:59 PM
Got a free 5gal bucket of Mobil SHC 627
by MinamiKotaro
02/12/16 02:59 PM
Hard starting LCT snow engine..
by JTK
02/12/16 02:34 PM
low-temperature oil gelling reversible?
by DrRoughneck
02/12/16 12:51 PM
I HAD to do it!
by Kuato
02/12/16 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
02/12/16 11:39 AM
Engine Light Advice
by coopns
02/12/16 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
02/12/16 11:09 AM
What happened to the thin oil movement?
by camrydriver111
02/12/16 10:57 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
100 registered (2010Civic, 333jeffery, 18LateModelFan, 97K15004WD, 901Memphis, 19kj57, 10 invisible), 1707 Guests and 192 Spiders online.
56901 Members
66 Forums
244606 Topics
#3247607 - 01/13/14 10:13 PM 1995 Buick Century Tune Up Questions
boostedtsiawd Offline
Loc: ILL
So i looked in the manual of my 95 Buick century 3.1 v6 and it says it takes standard spark plugs acdelco r44ltsm6 but i wanted to put platinum plugs in instead since i heard there better is it ok and do i have to gap the platinums or just throw them in there? also which platinum plugs do i get and it doesnt say what type of wires it needs?
Edited by boostedtsiawd (01/13/14 10:14 PM)
#3247610 - 01/13/14 10:15 PM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
Barkleymut Offline
Loc: Richmond, VA
how old are your current wires? as for the plugs, I would guess almost anything works in those old GM v6s but I will defer to the more edumacated crowd.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#3247612 - 01/13/14 10:17 PM Re: 1995 Buick Century Tune Up Questions [Re: Barkleymut]
Loc: ILL
i have no idea how old the wires are i bought this car a year ago and havent changed the plugs or wires...
#3247632 - 01/13/14 10:47 PM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
SuperDave456 Offline
Loc: Dallas, Texas
Take a look at the wires.
Are they looking beat up? Cracked? Like they have been there awhile?
Pull a couple of the plugs.
Can you tell if they are platinum? Copper?
How are they looking?
Maybe take a picture and post it.
If your 18 year old car is still running then everything you are looking at has been replaced more than once.
The most inexpensive thing to do is to determine what you have going on and how much life is left before you start replacing things.
My 2002 Ford Taurus can go almost 90,000 miles on a set of Platinum plugs. If someone has recently replaced them in your vehicle, along with wires cap and rotor, then you are good to go.
Unless you are having some kind of misfire or something else going on.
#3247642 - 01/13/14 11:03 PM Re: 1995 Buick Century Tune Up Questions [Re: SuperDave456]
Loc: ILL
my car doesnt have a cap n rotor though...
#3247665 - 01/13/14 11:42 PM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
crazyoildude Offline
Loc: New Jersey
that is a great car and great engine and it will run a long time use the plugs that gm used when it was new and there will be no problems clean the throttle body and use 5w30
My Personal Choice Of Engine Oil Is Usually PYB And PHM For My Dino Choices, As For Synthetic I Like The QSUD..
Oil Filters Anything Wix Or Fram Ultra.
#3247666 - 01/13/14 11:42 PM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
barkingspider Offline
Loc: socal
I think you are better off with delco or ngk plugs.
04 Chevy Silverado
13 BMW 328i (wife)
05 Toyota Camry
#3247716 - 01/14/14 02:35 AM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
demarpaint Offline
Loc: NY
I used Autolite Platinum plugs in my 00 Century. They had close to 87K miles at them when I replaced them. In all honesty they probably could have gone 100K miles. The wires were impossible to get off without splitting the boot, so I replaced them. Next time around I'll be sure to let the platinum plugs I put in go 100K miles if I have the car that long.
God Bless Our Troops
#3247720 - 01/14/14 03:02 AM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
KitaCam Online   content
Loc: SunnySouthFlorida
More preventative maintenance than "tune-up" but...
Change all fluids and rubber parts...
Oil of course, but coolant, brake, AT, and power steering...
Check/change hoses, belts, and mounts...
Any car that old will have "age" as well as "mileage" issues, particularly with liquids and rubber...
Kitacam is an 05 Camry LE/I4/MT; 6/15 @ 132,500....Pennzoil Plat-Plus 5w-30 for the hot summer...with Toyo filter
#3247728 - 01/14/14 03:31 AM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
eljefino Offline
Loc: ME
I would stay with copper plugs. It matters, these things can ping.
#3247748 - 01/14/14 05:13 AM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
NHGUY Offline
Loc: USA
Spark plug wires have date of manufacture written on them.By law.
#3247754 - 01/14/14 05:40 AM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
Trav Offline
Loc: MA, Mittelfranken.de
This engine uses a waste spark ignition system. Use only double precious metal electrode plugs.
Chances are if the wires have been on there a while you wont get them off in one piece, you may even have to slit the boots as demarpaint did, have a set standing by.
Clean the TB and MAF, new air filter, PCV and a bottle of Techron in the tank and it should be good to go.
I didn't forget the fuel filter but depending on rust you may be better of leaving it.
A vehicle this age still needs decent parts but don't get carried away. A set of Autolite double platinum plugs and Autolite pro wires work well.
Use a AAP online discount code and pick them up at your local store.
http://www.ngksparkplugs.com/pdf/dyk_waste_spark_ignitions.pdf
2cents
#3247771 - 01/14/14 06:22 AM Re: 1995 Buick Century Tune Up Questions [Re: boostedtsiawd]
bigt61 Online   content
Loc: Virginia
Is the CEL on? Is it idling smooth? If it's running OK, leave it alone. Those 3.1's had no power, replacing plugs isn't going to make it more peppy.
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#3247812 - 01/14/14 07:37 AM Re: 1995 Buick Century Tune Up Questions [Re: bigt61]
eljefino Offline
Loc: ME
For what they have for power the A-bodies move okay being under 3000 lbs. Tune ups every 30k on those. CEL won't light easily being OBD-I.
#3248684 - 01/14/14 10:42 PM Re: 1995 Buick Century Tune Up Questions [Re: bigt61]
Loc: New Jersey
they have ok power and are reliable
