Strange failure: Starter AND flywheel cogs ripped
by lars11
28 minutes 40 seconds ago
My email from Castrol about Magnatec
by Tech819
38 minutes 9 seconds ago
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
Today at 01:41 PM
Observations on Workplace corrosion
by Vdubuk
Today at 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
Today at 12:08 PM
First time flushing an 05 Tacoma
by Back40
Today at 11:53 AM
600-year-old plumbing works better than modern
by HTSS_TR
Today at 11:48 AM
Shopping for brand-new F-150
by jay929
Today at 11:35 AM
Audi Broken Oil Control Rings - Why???
by SonofJoe
Today at 11:27 AM
Royal Purple VS Mobil 1?
by 340six
Today at 11:09 AM
Condensing down to 1 vehicle
by krismoriah72
Today at 11:04 AM
Ford Focus door strip coming off
by FordBroncoVWJeta
Today at 10:41 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
94 registered (69GTX, Anduril, alanwayne1908, andrewlg, 2015_PSD, 4WD, 7 invisible), 2035 Guests and 10 Spiders online.
58632 Members
66 Forums
252405 Topics
Page 1 of 8 1 2 3 4 5 6 7 8 >
#3247477 - 01/13/14 08:35 PM Upper cylinder lube vs. oil additives
dino33 Offline
Loc: British Columbia
So, we like additives to extend our engine life, keep them running at top performance, and maybe even get some extra mileage with our fuel. the question is do we use additives and ignore an upper cylinder? Is a ucl as effective as an additive? And is there any evidence or proof that an upper cylinder lubricant is effective at lessening wear and keeping your engine in top shape? For what it's worth I'm using ceretec/Mos2 with good oil. As well, I've been using Lucas ucl for the last year. I want to get at least a half a million kms out of the Prius. So far so good.... Thanks in advance...
2004 Toyota Prius 165K miles Redline 5w30 LG Biotech Fram Ultra filter
1996 Geo Metro gas mizer oil guzzling $300 pizza man car
Filtermag!
#3247491 - 01/13/14 08:45 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
gregk24 Offline
Loc: FL, USA
I believe additives are unnecessary with a quality oil.
2012 Honda Accord EX-L
Taffeta White - Ivory
39,xxx miles
PPPP 0w20 / Fram Ultra
#3247493 - 01/13/14 08:47 PM Re: Upper cylinder lube vs. oil additives [Re: gregk24]
dino33 Offline
A lot of people have that opinion. What do you think about a good UCL?
Filtermag!
#3247496 - 01/13/14 08:49 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
AandPDan Offline
Loc: MA
Additives are a waste of money.
#3247505 - 01/13/14 08:58 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
EricG Offline
Loc: SW Louisiana
Ask yourself what an upper cylinder lube does that a lower cylinder lube (AKA, motor oil) does not do!
#3247507 - 01/13/14 09:00 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
Ducked Offline
Loc: Taiwan
It DOES NOT MATTER what we think about UCL's.
To answer your question usefully, you'd need the statistics for long term wear-related engine failure modes for the Toyota Prius.
If upper-cylinder wear was a (or the) predominant cause of failure (requiring an engine rebuild) then UCL would be worth further consideration.
I'd bet money that no one is going to post that information on here. I suspect even Toyota may not have that information, but they'd be the people to ask.
#3247532 - 01/13/14 09:13 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
Donald Offline
Loc: Upstate NY
Who is we??
Use high quality synthetic oil and forget the additives.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3247544 - 01/13/14 09:21 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
NMBurb02 Offline
Loc: Crowntown, CA
Many board members run TC-W3 2-stroke oil and/or MMO in their gas as an UCL. I experimented a bit myself with MMO, TC-W3, and a MMO/TC-W3 mix in the gas and saw no real improvements in mileage or motor oil consumption (some say running an UCL results in a better ring seal and therefore less motor oil pushing past the rings into the combustion chamber). I gave up completely with the GP and am finishing off my current supply of TC-W3, but may pick up again with some MMO dosing in both just to see what happens.
I don't know that anyone has made claims of better engine longevity from use of an UCL. Clams have mostly been related to fuel efficiency, smooth engine running, and/or improved butt dyno results.
2002 Chevy Suburban 1500, G-Oil 5W-30, Fram TG3675
2006 Pontiac Grand Prix GT, M1 0W-40, Fram TG3387A
#3247549 - 01/13/14 09:22 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
Clevy Offline
Loc: Saskatoon canada
As far as upper cylinder lubes go I cannot say for sure whether they affect wear in any measurable way however I still use tc-w3 in my fuel just in case. It costs pennies to treat a tankful and hasn't hurt yet. I've never had a fouled plug or anything.
Tc-w3 has detergents in it and because it's an oil it may help fuel pumps and rubber seals exposed to the drying effects of ethanol.
Either way its cheap and in my mind its not hurting anything.
2006 Charger RT
Miles x 2 per oil filter
#3247574 - 01/13/14 09:38 PM Re: Upper cylinder lube vs. oil additives [Re: Clevy]
turtlevette Offline
Loc: Massachusetts
I assume you're running much less than a 50:1 ratio as used in outboard motors. Does it produce that stinky exhaust that outboards have? What is the threshold?
USA-1
#3247584 - 01/13/14 09:47 PM Re: Upper cylinder lube vs. oil additives [Re: Clevy]
Finz Offline
Loc: Northern NJ
+1
God Bless America... We really need it about now
06 Odyssey
06 Civic coupe
05 Accord 2.4 sedan
11 Civic 1.8 sedan
98 Accord 2.3 sedan
#3247588 - 01/13/14 09:51 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
Cujet Offline
Loc: Jupiter, Florida
I hate to admit it, but I tried MMO in the gas in my 2003 Jaguar X-Type 2.5L V6. I was experiencing a rough idle and started thinking about poor valve sealing, sticky rings, balky injectors and so on. Considering that MMO has been known to help in such matters, I tried it. Success!
I added nearly a quart of the stuff to a 15 gallon tank. The engine was nearly instantly smooth. And, it clearly remains so many tanks later.
What happened? I really don't know. And, while I prefer scientific methodology and reasoning over "old wives tales", I can only speculate on the reasons why it worked. I will refrain from doing so.
Turbo's rule.
#3247589 - 01/13/14 09:51 PM Re: Upper cylinder lube vs. oil additives [Re: turtlevette]
Finz Offline
Loc: Northern NJ
Personally, I'm running 1 oz to every 5 gals of petrol... 600:1
06 Odyssey
06 Civic coupe
05 Accord 2.4 sedan
11 Civic 1.8 sedan
98 Accord 2.3 sedan
#3247621 - 01/13/14 10:29 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
MinamiKotaro Offline
Loc: TN
I put MMO in my Bug's gas because it makes the fuel pump quieter. The pump is INCREDIBLY loud otherwise. Any cleaning or other benefits are simply a plus.
I'll be trying TCW3 shortly. Its a lot thicker so I imagine it would do more to quieten the pump. The Pennzoil kind is cheaper than MMO so if it does the job I'll switch.
I've been putting Lucas UCL in my Polaris, mostly to use it up as it did absolutely nothing for quieting the fuel pump in the Bug. I can't really tell any difference using vs. not using it.
I found a box of mothballs and I've been putting them in the brown van, one per fill-up, to see if the old-timers may have been onto something. The thing seems to be smoother but no improvement in MPG, or anything. Could be my imagination or the naphtha may have cleaned out a little something in the carburetor.
1967 VW Beetle: Mag1 5w40 All Fleet/Motorcraft FL400S
2004 Saturn Ion: Delo 5w40/Wix 57082XP
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
#3247623 - 01/13/14 10:31 PM Re: Upper cylinder lube vs. oil additives [Re: dino33]
mongo161 Offline
Loc: Coney Island, NY
A blended mix of 1 oz, per gallon of Gas, for TC-W3 and 3 ounces of Chevron Techron at every fill up or every other fill up. It's very important to use this mix when the Winter Gas is sold at the pump. This mix will lube everything between the gas tank and the upper cylinder.
Don't forget to use ONLY TC-W3 since this engine oil is "ash-less" and burns clean. The 3 ounces of Chevron Techron Fuel System cleaner at every fill up is just a maintenance dose and combined with the TC-W3 it fills up my empty 6 ounce bottles that are used for dosing at fill up time.
I've been using this combo for 3+ years now and I've never had a problem.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
