'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Briggs and stratton flathead?
by pdxglocker9mm
05/03/16 10:27 PM
Charcoal
by dlundblad
05/03/16 09:43 PM
2013 Dodge Dart: replace AF on miles or time?
by vitez
05/03/16 09:20 PM
Rotella T5 10w30 or QSUD 5w30
by GumbyJarvis
05/03/16 09:04 PM
People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
747-400 versus 747-8
by mjoekingz28
05/03/16 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
05/03/16 07:47 PM
'13 Wrangler 2.5" lift
by JXW
05/03/16 07:37 PM
group 7 v6128 ford 6.7 7k miles
by robo339
05/03/16 07:34 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
77 registered (2015_PSD, barkingspider, 901Memphis, aquariuscsm, 10 invisible), 1204 Guests and 101 Spiders online.
57779 Members
66 Forums
248434 Topics
Page 2 of 3 < 1 2 3 >
#3228142 - 12/26/13 10:06 AM Re: Valvoline Maxlife [Re: volk06]
BlueOvalFitter Offline
Loc: Cajun Country, La.
Originally Posted By: volk06
Originally Posted By: BlueOvalFitter
I see that VML and QS Defy are synthetic blend HM oils. Are all HM oils, that are not synthetic HM oils, synthetic blend?
When looking at the msds for Defy, it looks like it is actually a full synthetic but not labels as one...
http://www.quakerstate.com/#/motor-oil/defy
That information must be a misprint. If not, it's a darn good deal for synthetic HM oil.
2007 F150 XL, 4.2 V6, 4R75E Transmission
Pennzoil Platinum HM 5W30, M1-209 Oil Filter
"One Filter, One OCI!"
USA
#3228285 - 12/26/13 12:46 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
volk06 Offline
Loc: Iowa
Heres a link to the msds, it just says synthetic base oil with the highly refined mineral oil present as additive diluent. My guess is its labeled as a blend but is mostly full synthetic. Just like how most dinos are a synblend.
http://www.epc.shell.com/Docs/GSAP_msds_00353682.PDF
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3228310 - 12/26/13 01:19 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
Triton_330 Offline
Loc: Illinois, USA
I recently put some VML 10w-40 synthetic blend in my dads '99 Ford Escort. In general that car's engine is just noisy because it's a 4 banger, but to me, the VML did quiet it down, and made it easier to start in the winter.
'01 Ford F-150 XLT 5.4L w/K&N CAI ~126k
-> Castrol Magnatec 5w-20 w/Fram Ulra
'89 Chevy Camaro RS 305 TBI ~48k
-> Pennzoil YB 5w-30 w/AC Delco
#3228409 - 12/26/13 03:21 PM Re: Valvoline Maxlife [Re: Triton_330]
volk06 Offline
Loc: Iowa
I see you have some kendall, how are you liking it? I've been running the full synthetic kendall in my F150.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3228416 - 12/26/13 03:28 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
abdodge1500 Offline
Loc: Florida
The 360 in my Dodge seems to run smooth and quiet with VML 10W-30 in it. It sounds a whole lot better since I put a flowmaster 44 muffler on it.
Edited by abdodge1500 (12/26/13 03:31 PM)
2000 Dodge Ram 1500 5.9L 144k Valvoline ML 10W-30
4spd Auto, Mopar/Autozone Tranny Fluid
Mopar Oil Filter MO-090
Technician at Tuffy Auto Service Center
#3228444 - 12/26/13 04:03 PM Re: Valvoline Maxlife [Re: volk06]
Triton_330 Offline
Loc: Illinois, USA
I like it quite a bit. I'm using the semi-syn blend. It seems to start easier in the winter than it has before - I used to just run PYB all year, but the cold harsh winters has been enough for me to learn better than to make my truck suffer rough cold starts. Last winter when it was running PYB and temps were below zero (*F), when I went to start it, it would shutter at 500 rpm's for a few seconds before revving up to its normal rpm range. But now, with the Kendall semi-synthetic in it, cold starts are no longer a problem.
#3244157 - 01/10/14 05:19 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
The job my son is working on is 61.7 miles one way. The last time he added a qt. of VML he had driven about 1150 miles. After putting almost 1230 miles in the last 2 weeks he had to add another qt. of VML. Some might say that's a lot of oil in such a short period of time, and at that mileage. But, the VML is working, and better than the ST HM oil. He was having to add a qt. of ST HM every 1K miles. And, with conventional oil, a qt. about every 800-900 miles.
I will say that VML is doing its job, and works! thumbsup
BTW, his company has him starting at a new job next week. It's only 22 miles one way. smile
USA
#3246492 - 01/13/14 12:34 AM Re: Valvoline Maxlife [Re: BlueOvalFitter]
Triton_330 Offline
Loc: Illinois, USA
To be honest, IMO, I think that the reason older vehicles burn so much oil (when using High Mileage oil) is that, because [generally speaking] additives are the first thing to be burnt off, and high mileage oils use more (yes, of a specific type of the many types) of additives, and so the makeup of the container may have less base stock in comparison to its oil/additive ratio. I may be wrong, as it is just a hunch. And if you prove me otherwise, I would totally admit to being wrong if I understood why. Anyways, to get to the point, I'd stay away from Valvoline's conventional Max Life. Go for the Semi-Syn Max Life.
I am not a basher of any brand, and I normally just go for the best deal, but (just because) I thought you might like to know that you can get oil for great prices on Amazon, plus the filter (and normally it's all free shipping [at least in the USA].
Just 'cuz, here are a few links for you to check out if you would like:
Mag1 5w-30 full syn 30 bucks 6 qts
Mag1 full syn euro 5w-40 for 37 bucks 6 qts
Rotella 5w-40 full syn gallon for 21 bucks
Valvoline semi-syn 10w40 for 27 bucks 5 qt jug
Of course, there's more good deals on Amazon, Walmart, and sometimes Oreilly's (I just got 5 qts of castrol syn blend plus a wix filter for 27 bucks).
There's always good deals for oil out there, but my advice for the oil burning problem is to add some Rislone: Rislone with zddp super concentrate for 7 bucks.
Best Regards, and I hope you can get something to help that oil burning problem grin
#3246498 - 01/13/14 12:40 AM Re: Valvoline Maxlife [Re: BlueOvalFitter]
zerosoma Offline
Loc: Omaha, NE
Originally Posted By: GutsyGecko
I was just referring to the possibility that the VML might be slightly thicker at temp than the ST oil. Sometimes a slightly thicker oil will lessen the noise. But if the change from 5w-30 didn't lessen the noise, it's gotta be something in the add pack. Likely Boron.
GG, you're the 2nd one to state that. I have also read a lot about VML. People that have used it think it was Heaven sent by Unicorns. And, I state that in a positive way.
Valvoline and it's counterparts are pretty much all I'll use anymore. Exception is Mobil 1 and pennzoil, but the V is my número uno. For these reasons.
2004 Hyundai Santa Fe LX 3.5L V6 (118k) [Mobil 1 0w40]
#3246532 - 01/13/14 03:02 AM Re: Valvoline Maxlife [Re: Triton_330]
My son buys 10W40 VML syn-blend from WM for $16.27 in the 5 qt. container. I sent him (2) coupons for $5 off each 5qt. container, back in November. That made the deal even sweeter. thumbsup
USA
#3246562 - 01/13/14 05:51 AM Re: Valvoline Maxlife [Re: BlueOvalFitter]
Char Baby Offline
Loc: Western NY
How is the consumption now?
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3246695 - 01/13/14 09:03 AM Re: Valvoline Maxlife [Re: Char Baby]
A qt. about every 1200 miles.
He says there is no oil leaking so it must be burning it.
1996 Corolla, 206K miles
USA
#3246881 - 01/13/14 12:04 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
Nodak Offline
Loc: North Dakota
My wife drives an 03 Corolla with 122,000 + on it and it burns little oil - we use QSUD in it. I drive an 04 Rav4 with 214,000 + on it and it used to burn oil at about your rate till I changed the PCV valve and switched to VML. Now it burns about 1.5 qrts. in 3000 miles. Runs like a top and I am a definitely going to keep using VML. ( I did try Havoline HM in it to see if it was just the PCV valve and the VML was more effective). There is probably other oils that will do the job like VML, but as for me, I will stick with VML.
___________________________
03 Corolla-5-30 QSUD and Wix filter
04 Rav4-5-30 VML and Wix filter
#3247322 - 01/13/14 06:15 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
Char Baby Offline
Loc: Western NY
I am liking the QS Defy also, especially for the extra level of quietness it provides.
"Retired"
#3247663 - 01/13/14 11:37 PM Re: Valvoline Maxlife [Re: BlueOvalFitter]
Triton_330 Offline
Loc: Illinois, USA
My son buys 10W-40 VML syn-blend from WM for $16.27 in the 5 qt. container. I sent him (2) coupons for $5 off each 5qt. container, back in November. That made the deal even sweeter. thumbsup
Haha, you know something... IDK why I linked the VML 10w-40 to Amazon, lol, because in that case, Walmart does sell it for much cheaper. Oh well, I must've been a little tired at the time of the posting haha. Yah, my dad recently bought it at Walmart for about 16 bucks (VML 10w-40 High Mileage Semi-Syn [Walmart]). He didn't have/use any coupons though...
(Warning, slightly unrelated and long read ahead): On a side note, unfortunately, the vehicle he'd put it in [that had a bad engine to begin with] recently just seized up. It was a 1999 Ford Escort... We found out by the mechanic that those 2.0L (not the zetec one, the standard one) from that generation had weak valve heads --- which lead to loss of compression, etc., and thus causing the engine to literally make cylinders 2 and 4 stop moving altogether. What's even funnier (not) is that when he bought the car (had around 100k miles), unsurprisingly, the previous owner had not tuned it as it should have been, and once my dad hit 150k the timing belt/chain (can't remember which it is) went bad - he went to start it up and 'snap crackle pop' (it shattered the pistons). The replacement engine (yah, what a great idea, replace an engine of a '99 Escort) would have been fine, but the goof-ball guys that put it in messed it up, and it, too blew. So the third engine (I know what your thinking here, lol), the most recent one, lasted for a good 80k miles until the weak heads killed it. All in all, that Escort did quite well though, despite a slippery transmission past 230k. The car was finally put to rest with like 260k miles on it, and throughout its whole life made 34mpg highway. cool
A few days ago my dad and I went out and bought a 1998 Buick LeSabre (about 98k miles on it) for a pretty good deal under KBB. I think my dad will be happy with this car. The 3.8L V6 (3800 series II) is a solid engine as far as I've heard. And for such a big car to get 30mpg highway thumbsup ... Ha, well, is pretty awesome. Also, when we bought it, the dealer had just gotten it in as a trade in so they'd not had time to even change the oil or anything yet (but that made it cheaper for us to buy haha), so I today I went to Walmart and bought something that I'd never have bought before I was a BITOGer - a 5 quart jug of Super Tech HM 5w-30. I thought, hey, for under 15 bucks, why not. I bought some STP blue bottle additive (for peace of mind, haha) and a Purolator filter, too.
