08 caravan / oil seeping from spark plug
by Mark72
Yesterday at 11:25 PM
Holley Accelerator pump probem
by nwjones18
Yesterday at 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
Yesterday at 10:37 PM
on line data search programs - which is best?
by bmwjohn
Yesterday at 10:11 PM
What size air compressor is needed
by ram_man
Yesterday at 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
Yesterday at 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
Yesterday at 08:20 PM
Best Oil Analysis?
by countryboy9799
Yesterday at 07:28 PM
Left my lights on and battery died.
by joegreen
Yesterday at 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
Yesterday at 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
Yesterday at 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
25 registered (deoxy4, BlueKelah, AEHaas, DaveBinVa, 1345, 3 invisible), 508 Guests and 93 Spiders online.
56902 Members
66 Forums
244626 Topics
Page 3 of 4 < 1 2 3 4 >
#3247272 - 01/13/14 05:32 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
SHOZ Offline
Loc: Illinois
M1 0w40.
I've run the 5w30 M1 and it will hit the 75 lbs when cold.
I should add I have a remote filter but the pressure sensor is after that.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#3247281 - 01/13/14 05:38 PM Re: Running 0W-40 where 5W-30 is specified [Re: aquariuscsm]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Originally Posted By: aquariuscsm
My car came with a sticker under the hood that says "10W is preferred" and recommends 10W30 and 10W40. Is their any advantages to me running 10W40 instead of 10W30 "wear wise" and/or vise versa?
And 15W-40 was spec'd for '96 BMW and even heavier grades for my '86 Porsche but 5W-30 and 0W-40 have been back spec'd for both cars respectively.
GC 0W-30 or M1 0W-40 would both be superior choices to a 10W-40 for a 300ZX. Even QS Defy 5W-30 would be a good choice.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3247290 - 01/13/14 05:44 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
Clevy Offline
Loc: Saskatoon canada
Originally Posted By: Shannow
If you have a pressure gauge, it reaches a figure then stays pegged. You can rev it cold, and see where it tops out at.
If you aren't on it continuously, then no problem...if you are, then still no problem, you are wasting energy.
My charger hits that at 65psi. It won't go any higher so I'm assuming that's my by-pass psi.
Originally Posted By: novadude
I don't really care if the pump is in bypass at high revs. I don't spend a lot of time at high revs. Besides, ALL oil pumps go into bypass at high revs, even with 0W-20.
Higher HTHS generally means higher film strength too, right? Better protecion?
Well not really.
If your engine only requires "x" film strength adding more doesn't mean less wear because the moving parts have an oil film separating them. A thicker oil film will add drag even if it's minutely.
However like I've already said the 0w-40 is something special. Nissan recommended it specifically for their race engines as well as Porsche and so on.
It's the only oil I'd break my boycott for to be honest,unless of course it was really cheap.
2006 Charger RT
Miles x 2 per oil filter
#3247292 - 01/13/14 05:45 PM Re: Running 0W-40 where 5W-30 is specified [Re: SHOZ]
CATERHAM Offline
Originally Posted By: SHOZ
M1 0w40.
M1 0W-40 is heavier than necessary since you're not seeing high oil temp's.
I'd resume using the recommended 5W-30 grade at the next OCI.
#3247297 - 01/13/14 05:52 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
SHOZ Offline
Loc: Illinois
That's my plan. Originally I did have oil temp problems big time. I then put on a tube and fin oil cooler that was less that stellar in performance and the adapter for it had thermostatic control at 160F. Too low when it was cool and was marginally effective when it was hot.
I've since gone to a water/oil heat exchanger on the filter mount. The radiator is way bigger than stock. I'm hoping this will take care of the heat. Most I've seen since putting that on is 215F at +90F ambient, AC on and 75 mph interstate travel. When it is cold the temp runs around 170-180F. T-stat is 180F.
#3247298 - 01/13/14 05:53 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
CATERHAM Offline
Yes even with a 0W-20 you'll need oil temp's of 65-70C before you can use maximum rev's out of by-pass.
Higher HTHSV means the oil is heavier, period even at low normal operating temp's. It's simply more accurate to refer to an oil's HTHSV rating (if you know it) than it's KV100 spec'.
#3247483 - 01/13/14 08:37 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
Shannow Online   content
Loc: Oz
Why would you be limiting your revs to stay out of bypass relief ?
Limiting revs because your pistons aren't round, and your block isn't straight is sensible...not bypass.
#3247509 - 01/13/14 09:00 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
SHOZ Offline
Loc: Illinois
At least for me the coolant can be up to temp, it is the oil that takes another 10 minutes/miles.
#3247735 - 01/14/14 04:17 AM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
virginoil Offline
Loc: western australia
Penrite has a plus 10 philosophy for vehicles in OZ see link below.
http://www.penriteoil.com.au/tech_pdfs/2...Extra%20Ten.pdf
The +10 is self explanatory. Unless you see snow I would use M1 5w-40 grade ie the same brand and additive package used by M1 5w30.
However at 147 000 miles ie approx 250 000 kms why change ?
Enough posts about switching causing leaks on this forum. The add pack in M1 0w40 I understand has much better cleaning properties, is it something you want to risk and take on at this stage of engine life ?
In summary IMO if its all good.
1. Thank God
2. Keep doing what you have been doing.
3. Switching causing leaks is not myth.
Edited by virginoil (01/14/14 04:30 AM)
#3248067 - 01/14/14 12:04 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
Maxima97 Offline
Loc: WA - Washington
People in this forum thought they were out smarter than oil refinary and auto manufacturer by mixing their own cocktail without scientific proof. The result is unknown. But there must be a reason user manual suggests using particular weight of oil.
97 Maxima, Maxlife 5W30
99 LX470,PU 5W30
98 Explorer,PU 5W30
93 Prizm, PU 5W30
01 Camry,G oil 5W30
95 Villager,Maxlife 5W30
05 Accord,Idemitsu 0W20
#3248172 - 01/14/14 01:59 PM Re: Running 0W-40 where 5W-30 is specified [Re: CATERHAM]
ukmastermind Offline
Loc: Los Angeles, CA
Doesn't 0w-40 have better flow at any lower temp. than 5w-30??
That + the extra zinc/phos would make the 0w-40 better in my book smile
#3248312 - 01/14/14 03:56 PM Re: Running 0W-40 where 5W-30 is specified [Re: ukmastermind]
901Memphis Offline
Loc: Northern Kentucky
No not necessarily. Depending on the product the 5w30 synthetic should be lighter until a certain point.
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3248425 - 01/14/14 06:40 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
ziggy Offline
Loc: stamford, CT
Would 0w40, or a 5w40 be better for a car that specifies 5w30 (98 corolla) in humid 97-102 degree heat, be better? Last year i ran 10w30 peak synthetic, it was good, but the engine had a watery consistency, i can sense it the oil. would a 0w40 or 5 or even 10w40 be better at those temps?
What i found out, was a 10w30 dino ate up a bit more fuel on me.2 miles a gllon a member here stated to me. the 10w30 synthetic didnt really eat up as much. so becuase its 40 weight, be it 0,5,10..ide imiagine fuel would go up quite abit on me.
#3248468 - 01/14/14 07:23 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
901Memphis Offline
Ziggy if your cooling system is working properly you should be using an API SN 5w30.
#3297520 - 02/28/14 04:04 PM Re: Running 0W-40 where 5W-30 is specified [Re: novadude]
splineman Offline
Loc: New Zealand
Penrite recommend the HPR 5 5w-40 as a 5w-30 replacement.
Am I correct in saying that at HTHSV of 3.9 it is too thick, across all temps, as a direct 5w-30 replacement?
Excuse my ignorance if this has been spelled out.
'05 Sportster 1200
'89 Honda GB 400
