Changed my oil on my 2002 Civic yesterday, 5000 mile interval. When i pulled the filter off, their was no oil in the filter. Obviously the ADBV wasnt working properly. The filter was a Purolator PureONE.
Today i checked my oil and its reading half a quart high (overfilled). Originally i had put the exact 3.4qt that the manual specs for this car. Do you think the ADBV is not working on the new filter (Fram ToughGuard), and is causing it to appear overfilled?
If so, these are two high quality filters with failing ADBV, im starting to think it is a mechanical problem. I would also like to add, that the oil filter sits horizontal at a 90* angle.
