I have been noticing some dimming on my dash lights when i turn my rear defroster on or have too many things going on at once, like my headlights, heat, and defroster at the same time, so i swung by Autozone to have my battery tested (AAP was closed), and they only have this little rinky dink tester that says pass or fail, it didn't print out a test slip like AAP does or even tell me the amps, it just said my battery was bad.
My battery is an Autocraft Gold 78-2 770 CCA and he put 770 into the tester unit correctly and i think it was reading 12.71v when the engine was just shut off. I was trying to look at the tester while he was working it.
http://shop.advanceautoparts.com/webapp/...earchTerm=78-2+
What do you guys think? I am going to go to Advance tomorrow to get a printout of the ACTUAL cranking amps, but just wondering what is considered warranty replaceable. Don't know if they are going to replace it if its still putting 700 amps instead of 770, but would like to have some ammunition in case they try to screw me.
The battery was bought in Feb 2013. I didn't have much trouble starting in -10F with PP 5w30.
