Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
25 registered (EchoTech1945, dmack2, AnthemBassMan, car51, Char Baby, austinlunsford, 2 invisible), 794 Guests and 12 Spiders online.
58584 Members
66 Forums
252221 Topics
#3245338 - 01/11/14 09:21 PM Liquid Wrench chain lube
nomochevys Offline
Loc: Ky
I saw some of this tonight at my local China mart for 3.77 a can. I was wondering if anybody here has tried it and what do you think of it. Its quite a bit cheaper than the dupont stuff I have been using and I would not have to order it online and pay shipping.
http://www.liquidwrench.com/pressroom/releases/pressreleases_detail.asp?r=1
#3245349 - 01/11/14 09:27 PM Re: Liquid Wrench chain lube [Re: nomochevys]
Robenstein Offline
Loc: Central IA
It works fine, just flings off more than the DuPont stuff. Works well as a cable lube also. Best to put it on a warm chain as it will evaporate off some of the more volatile compounds and fling less when you take it out. I keep a can around for use in a pinch. It is definitely in the "runny" camp of chain lubes.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#3245397 - 01/11/14 10:36 PM Re: Liquid Wrench chain lube [Re: nomochevys]
spasm3 Offline
Loc: out there
I have some of it works fine if you let it sit 1/2 hour before riding. I want to try the shaeffers #227 moly chain lube. I may order some for next spring.
Edited by spasm3 (01/11/14 10:37 PM)
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3245696 - 01/12/14 10:21 AM Re: Liquid Wrench chain lube [Re: nomochevys]
buck91 Offline
Loc: West Michigan
Ive switched from T9 to this for bike chains due to pricing. Cant say its better but it definately works great. As others have mentioned give it a while to dry. Which it does end up drying into a waft film much like the boeshield
Its supposed to have some EP organic moly so it should handle high loads alright but no nastily black [censored]. That all said, and while I haven't noticed a deficit, it is not my go-to corrosion inhibitor.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3246131 - 01/12/14 05:45 PM Re: Liquid Wrench chain lube [Re: nomochevys]
Cardenio327 Offline
Loc: Oaxaca, Mexico
I used it for 3 years. Chain didn't wear much, but it bakes onto anywhere it splatters. I use 50/50% ATF/SAE 140 now; splatters a little more but doesn't stick.
'08 Honda C90ST Super Cub 15w-40 Delvac 1300
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 5w-20 PP
'99 F-150 W/T 4.2L 10w-30 QSUD
#3246840 - 01/13/14 11:34 AM Re: Liquid Wrench chain lube [Re: nomochevys]
Ken2 Offline
Loc: Washington St.
On the V-Strom forum we've found that almost any lube works quite well, 20+ thousand miles on those bikes. For some reason, the current yellow-can Dupont Teflon chain lube seems to be weaker than the older blue-can Dupont multi-purpose wax lube. The current blue-can Dupont multipurpose lube without wax is very weak. Many riders have their favorites, but the only thing that seems to stand out are the continuous lubricators, and those often make a mess as well cost a fair bit for the hardware.
Here's why an o-ring chain needs lube:
http://www.ekchain.jp/feature/index.html
It isn't the o-ring or x-ring or xyz-ring that needs the lube. It is the outer roller that does not have lube sealed in by the sealing ring. The pin and inner bushing have the sealed-in factory lube.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
