Changed the oil on my Dad's 2003 Hyundai Elantra today. It has about 104,000 miles. I think the oil and filter had about 7,000 miles on it, but now that I've seen the inside of the filter, I'm going to see if I can pin the mileage down more precisely.
First, the money shot:
The ADBV was pretty stiff, and a little wavy. I don't think it was doing anything, since after sitting base down for 5 minutes, there wasn't a teaspoon of oil left in the filter. I realize that most of the oil will drain out through the filter element, but there's usually a fair amount left when I cut the filter open.
Here's the base end bypass. The wavy material in the middle was pretty hard.
I'm not going to say that this turned me off of Pro Select filters - I wasn't a fan of them to start with. I will say that of the 10 or 15 filters I've cut open, this is the first one that had an obvious problem.
