Keep it simple.
by JustinH
05/06/16 03:28 PM
Pennzoil Ultra Platinum, 5W-30, 5k OCI, 20k total
by Joshua_Skinner
05/06/16 02:26 PM
Amsoil 75w90, 45K, 04 Chevy Tahoe
by dhellman12
05/06/16 02:09 PM
What happened to this kind of oil change?
by OneEyeJack
05/06/16 01:44 PM
OH! OH! Gas/Diesel mixup
by azjake
05/06/16 01:09 PM
VOA Pennzoil Platinum Euro 5w40 - SN
by agpatel
05/06/16 12:36 PM
VOA Liqui Moly Leichtlauf High Tech 5w40
by agpatel
05/06/16 12:30 PM
VOA Castrol Edge with Ti - 0w40 - SN - Euro Form
by agpatel
05/06/16 12:27 PM
Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
96 registered (agpatel, 69GTX, 137_Trenton, 2010Civic, 09_GXP, 12 invisible), 1 Guest and 0 Spiders online.
57814 Members
66 Forums
248551 Topics
#3242152 - 01/08/14 06:23 PM Australian Ford Ranger 3.2l 5cyl - 11.3k km
TeeBee48 Offline
Loc: Perth, Australia
Hi all,
Had a UOA done on my 2013 5cyl TDCi Ford Ranger, factory fill I believe is Motorcraft Formula Ford "F" 5W-30, meeting WSS-M2C913-C which is a requirement for this engine. Motor is a 5 cylinder 3.2l turbo diesel with 147kW & 470Nm.
This sample was taken prior to the first oil change as per my dealers recommendations, hence why it has 11.3k km's on factory fill. First service is at 15k kms, so I want to make sure it was holding up prior to that service.
OIL Motorcraft Formula Ford "F" 5W-30
KM's IN USE 11.3k
KM's 11.3k
SAMPLE TAKEN 15/11/13
COMMENTS:
- Copper content is high and could indicate thrust washer/bearing wear.
- Silicon is elevated but is possibly due to the sealant used in assembly. Check at next service.
- A normalisation factor of 0.981 has been applied to the wear metals during final analysis.
- Other results are satisfactory.
- Wear may be due to equipment run-in. Resample in 250 hours to establish a compartment trend.
Code:
ALUMINUM        11
CHROMIUM        1.9
IRON            58
COPPER          58
LEAD            0
TIN             2
MOLYBDENUM      100
NICKEL          1
MANGANESE       22
SILVER          2
TITANIUM        0
POTASSIUM       6
BORON           93
SILICON         7
SODIUM          4
CALCIUM         2780
MAGNESIUM       22
PHOSPHORUS      662
ZINC            882
BARIUM          1
SULPHUR         2750
VANADIUM        0
CHROMIUM        1.9
CADMIUM         0.1
WATER           0.121
OXIDATION       12.4
NITRATION       7.56
FUEL DILUTION   0.8
TBN             8.76
I'd be interested to see everyones thoughts. Severe service interval for this vehicle is 7.5k kms but I rarely tow anything, however my wife drives the vehicle daily to work which is approximately 30kms each way.
Edited by TeeBee48 (01/08/14 06:29 PM)
2013 Ford PX Ranger - 3.2l TDCi Auto
#3242392 - 01/08/14 10:30 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
dustyroads Offline
Loc: upstate NY
Everything looks good for a new engine/factory fill. Nice add pack, too. Your wear metals should look much better next time as it wears in.
I'm so jealous of you with that diesel ranger! I'd love to have that option here. I hope it does well for you!
2011 Taurus sel
QSGB 5W20 MC FL500S
#3242400 - 01/08/14 10:40 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
Danno Offline
Loc: Northern Ontario, Canada
Hey TB48, How do you find that engine?
It will be going into the 2015 Ford Transit for North America and possibly the F150. I will be buying 100s of Transits for my fleet so very curious on your experience.
How much oil does it take?
#3242408 - 01/08/14 10:55 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: Danno]
TeeBee48 Offline
Hi Danno,
The engine itself is great, it has plenty of power and when coupled with the 6spd auto we have here, has really long legs on the open road. It has some low-rev turbo lag but it can be rectified with chips and/or throttle boosters that are on the market. Fuel economy is steady at 9.5l/100km (24M/gl) around town, and I've had it as low as 7.2l/100km (32M/gl) on the open road.
It takes approximately 10l of oil (9.7l I think)
#3242424 - 01/08/14 11:18 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: dustyroads]
TeeBee48 Offline
Cheers, I was actually pretty impressed with how well its stood up, I'm reasonably confident that it will easily last 15k kms. If I do any heavy, regular towing or take it off road then I will drop intervals to 7.5k kms, but so far so good.
I actually cant believe that you guys dont get this motor in a pickup up there!
#3242438 - 01/08/14 11:39 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: dustyroads]
Clevy Offline
Loc: Saskatoon canada
+1. In a ranger too. Awesome.
2006 Charger RT
Miles x 2 per oil filter
#3242486 - 01/09/14 05:07 AM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
dnewton3 Offline
Loc: Indianapolis, IN
Typical wear on a new engine; nothing to be concerned about.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3242576 - 01/09/14 08:00 AM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
Danno Offline
Up to now, there has been no need. The mid-size pickup market has died and full-size pickups own the market. With gasoline cheaper than diesel and at $3.50 per gallon, the small diesel would have just died if launched.
However Ram (Dodge) just launched a 3.0L V-6 diesel in their Ram. I expect Ford to put your engine in the F150 to reply to Dodge as fuel economy measures tighten up.
Ram has a signifcant price premium on the small diesel of about $4.0K as well.
Decently equipped, these trucks can be on the road for $40.0K
Links to Ram diesel road test and full size comparo.
http://www.caranddriver.com/reviews/2014-ram-1500-ecodiesel-v-6-first-drive-review
http://www.caranddriver.com/comparisons/dodge-ram-vs-ford-f-150-and-chevy-silverado-comparison-test
#3243169 - 01/09/14 06:04 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
TeeBee48 Offline
I guess that's fair enough, some full size US pickups down here require you to hold a Light Rigid truck licence (in my state anyway), so there's not really that much demand because not everyone can drive them. Additionally, a RHD Silverado will set you back about AUD$120k down here so only really heavy towers are running them at the moment.
We have 3.0l V6 diesel in our version of the Nissan Frontier, which is currently the class leader in mid-size pickup engines. 170kW and 550Nm of torque. The Dodge looks like a decent truck though!
#3243407 - 01/09/14 11:06 PM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
Danno Offline
The Dodge is a fine looking truck. The Hemi 5.7L V8 is an awesome engine.
The Canadian dollar and AUD are similar in value. $120K for a pickup is skyhigh compared to Canada where a decent one is about $40K.
#3243532 - 01/10/14 06:44 AM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
dlundblad Offline
Loc: Midwest
Hi Danno,
I too am very jealous. shocked2
*on a side not, didn't Nissan have something with Dodge for a Diesel engine?
Edited by dlundblad (01/10/14 06:47 AM)
2003 Jeep Grand Cherokee / 4.0 / 180k
PYB 10w40 w/ 16% 5w20 / Fram TG16
2002 Volvo S60/ 2.4t / 150k
Mobil 1 0w40 / Mahle OX 149 D
#3243591 - 01/10/14 07:59 AM Re: Australian Ford Ranger 3.2l 5cyl - 11.3k km [Re: TeeBee48]
Danno Offline
Actually a 5.0L Cummins engine for Nissan. That engine should pull really hard.....
http://cumminsengines.com/cummins-5l-v8-turbo-diesel
