Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
by kohnen
05/26/16 11:23 AM
Mobil Delvac 1 ESP 5w-40 for 2011 TDI?
by ruleof72
05/26/16 10:49 AM
Husquvarna YTH2046 riding mower
by Donald
05/26/16 10:47 AM
Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
Thoughts on M1 V-Twin 20-50 Oil?
by ZZman
05/26/16 08:07 AM
Real Estate Rates
by AirgunSavant
05/26/16 06:30 AM
15w-40 in my boat, is diesel oil OK?
by chriscpmtmp
05/26/16 05:47 AM
20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Rdyno, Darsahn, jerryg, 1971tr350, Mak712
57990 Registered Users
92 registered (AirgunSavant, ARCOgraphite, badtlc, 1JZ_E46, AZjeff, Atesz792, 7 invisible), 1789 Guests and 310 Spiders online.
57990 Members
66 Forums
249424 Topics
#3243037 - 01/09/14 04:15 PM I think my Power Steering pump is going...
renegade_987 Offline
Loc: Ankeny, IA
So for the last couple months I'll get a strange whining noise around 60-70 MPH, but as soon as my foot comes off of the gas it stops. I'm not sure if this is related, but within the last 2 weeks when I accelerate from 0 to 35 or so I'll get a high pitched whine that lasts for 3-10 seconds, and its driving me nuts. It also happens ALOT when I'm idling. My dad was looking at it with me this morning and noticed that the power steering fluid was quite low, so we added some and the noise stopped instantly. When I started it to go to work about 20 minutes later, however, the noise was back and lasted for about 3 minutes. Like I said, its not full time, but Im wondering if its all PS related. One other thing, within the last 3 days I've been smelling a sweet, almost rubbery smell through the vents. Related????? Thanks!
2004 F150 186K Valvoline WB/Motorcraft FL-820S
2005 Ford 500 Limited 128K Motorcraft/Motorcraft
2011 Baja MB200 Royal Purple 10w30
#3243048 - 01/09/14 04:18 PM Re: I think my Power Steering pump is going... [Re: renegade_987]
440Magnum Offline
Loc: Texas
Did you check for PS system leaks? Sounds more like a leak than the pump to me.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3243057 - 01/09/14 04:22 PM Re: I think my Power Steering pump is going... [Re: 440Magnum]
Loc: Ankeny, IA
I had a small leak around my oil pan gasket that got all over my driveway so its hard to tell if there is anything else, but I'll look closer
#3243060 - 01/09/14 04:23 PM Re: I think my Power Steering pump is going... [Re: renegade_987]
2oldtommy Offline
Loc: Ohio
Check the tension on your PS pump belt as well as all other belts if not a serpentine belt. My guess is that one of the belts is slipping. FWIW
Oldtommy
#3243076 - 01/09/14 04:30 PM Re: I think my Power Steering pump is going... [Re: renegade_987]
toneydoc Online   happy
Loc: War Eagle
I would check the pump fluid again. It may have a leak or bad reservoir or something and be leaking out to cause the noise. If low fill it up again and start motor and see if noise goes away. If it does you have a leak somewhere.
1994 Jeep 146k Castrol 0w40
2014 Camry 14k TGMO 0w20
2010 Sebring 39k Valvoline 5w30
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3243082 - 01/09/14 04:35 PM Re: I think my Power Steering pump is going... [Re: renegade_987]
andyd Offline
Loc: Marshfield , MA
If it uses fluid , it has a leak. find the leak and fix it. Pmps make all sorts of noise when they are run low. Sooner or later you'll need a pump when you run it
low once too many times It may very well have a loose belt too. Keep body away from the moving belt when diagnosing. laugh
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3243141 - 01/09/14 05:18 PM Re: I think my Power Steering pump is going... [Re: renegade_987]
Trav Offline
Loc: MA, Mittelfranken.de
It sound like you may have an oil soaked belt from the oil pan leak.
#3243226 - 01/09/14 07:14 PM Re: I think my Power Steering pump is going... [Re: renegade_987]
ryansride2017 Offline
Loc: The coal hills of eastern PA
Did you flush the power steering fluid? Some models have fine screens in the reservoir that get crud in them that reduces flow. The pump might be making noise because it cannot pull the amount of fluid it requires (very common on Dodge's). It's actually not that expensive ($35) to replace the reservoir and perform a complete power steering fluid flush.
Edited by ryansride2017 (01/09/14 07:15 PM)
#3243473 - 01/10/14 02:36 AM Re: I think my Power Steering pump is going... [Re: renegade_987]
Californiabob Offline
Loc: Bay area CA
if you're low on PS -check the hose clamps to the pump.
If they're worm-type clamps then just tighten them.
happened to me, squeals, low fluid - tightening them solved it.
CaliforniaBob
#3243475 - 01/10/14 02:45 AM Re: I think my Power Steering pump is going... [Re: ryansride2017]
Barkleymut Offline
Loc: Richmond, VA
I was having similar problems as the OP except my fluid level was fine. I replaced the resevoir and all is good now. This was on the 2001 in my sig. My concern with the OP is his fluid was low. You have a leak, fix it and I will bet the problem is solved. Let us know.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
