Best Oil for [censored] Intek 19 HP Mower
by beadvised
6 minutes 24 seconds ago
Purolator Boss 14610
by bbhero
7 minutes 51 seconds ago
Was the original Mobil 1 a Straight 20?
by Gene K
26 minutes 27 seconds ago
Valvoline Maxlife 0w20 Synth blend?
by HKPolice
38 minutes 40 seconds ago
Walmart Canada (GTA) Valvoline MaxLife 0w20 $18.88
by HKPolice
Today at 11:49 AM
Makita B04510 Palm Sander - Fix?
by user52165
Today at 11:41 AM
Red Arrows
by Whitewolf
Today at 11:20 AM
Weber kettle barbecue grill thermometer placement.
by BigD1
Today at 11:19 AM
Gravity Waves: Evidence for Black Holes&Rel.
by MolaKule
Today at 11:07 AM
Car stereo choices
by 007
Today at 11:05 AM
Juicers: anyone have one?
by car51
Today at 10:57 AM
Tips for cooling down a hot car
by mclasser
Today at 10:52 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
64 registered (aquariuscsm, AandPDan, AirgunSavant, andyd, 007, 13 invisible), 2129 Guests and 12 Spiders online.
58257 Members
66 Forums
250793 Topics
Page 3 of 3 < 1 2 3
#3241906 - 01/08/14 02:20 PM Re: Troubling UOA [Re: MolaKule]
rhhsiao Offline
Loc: Los Angeles, CA
Originally Posted By: MolaKule
Originally Posted By: simple_gifts
Quote:
Did coolant somehow get in the oil? The K+ is lower but was really high initially.
Saw that but the glycol test is 0. Wonder if that is a valid test for VW coolant.
The big question is, why is the Potassium trending downward?
Did the FF oil contain a lot of Potassium agent?
What does the VOA of this current oil show in terms of Potassium?
The first few UOAs of the common rail diesels from VW all tend to show high potassium. I believe it's from the EGR system or the use of a welding flux.
#3242039 - 01/08/14 04:41 PM Re: Troubling UOA [Re: JMarshall]
JMarshall Offline
Loc: NW PA
What does anyone think of the plan of pulling a sample through the dipstick tube @ 4500 miles and seeing how it looks then?
#3242046 - 01/08/14 04:44 PM Re: Troubling UOA [Re: demarpaint]
JMarshall Offline
Loc: NW PA
10K OCI is too long, forget the owners manual, cut the interval in half and see how thing pan out. Just out of curiosity do you have an OLM? If so how long before it triggers an OCI?
It doesn't have oil life sensors like say a GM product. It has a service indicator that comes on after a set mileage/time regardless of driving habit/etc
#3242103 - 01/08/14 05:27 PM Re: Troubling UOA [Re: JMarshall]
gathermewool Offline
Loc: New England
I'd say just drain it, obtaining a sample midway through. If money is an issue, then do a couple of shorter (5-6k) OCI's without sampling, and then send out a sample of the third drain for analysis. The reason I suggest this, is because residual wear-like metals will still be present from previous intervals, so even if the oil looks fine after this run to 4,500 miles, the "wear" metals may erroneously appear alarmingly high. They should, however, trend downward due to dilution, the end of break-in, and less run time.
Also, remember that most diesel guys that I've talked to (note, I am NOT a diesel guy) don't consider their engines broken in until well after a gasser would be.
Edited by gathermewool (01/08/14 05:28 PM)
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3242111 - 01/08/14 05:34 PM Re: Troubling UOA [Re: gathermewool]
JMarshall Offline
Loc: NW PA
These engines normally aren't "broken in" and hit their peak compression numbers until ~60K miles. So you would just change it a couple times without sampling? Money isn't really an issue. My thought was at 4500 miles, if this high number was a fluke from catching oil out of the bottom of the pan, etc, that sampling at 4500 would allow me to still run the oil if it is in good shape, or change it out if need be.
#3242131 - 01/08/14 05:57 PM Re: Troubling UOA [Re: JMarshall]
rhhsiao Offline
I personally like this idea of sampling mid-run from the dipstick. There definitely could also be the possibility of contamination if you were getting samples from the bottom. I personally have a suspicion the oil itself is fine but a combo of break-in wear, biodiesel, cold weather starts, and hard driving are giving you wear numbers that look bad this early in the life of the engine. But what do I know? It's all really conjecture at this point anyway.
#3242175 - 01/08/14 06:50 PM Re: Troubling UOA [Re: JMarshall]
Loc: New England
More data is always better, so if you don't mind, we'd all love to see a sample at ~4,500 miles. If the results trend downward, then you can decide what your interval should be, based on how steep the trend is.
I wouldn't assume the numbers from the most recent analysis are bad - trust your indications. That doesn't mean to trust them blindly, which is why your verification sample isn't a bad idea at all. Worst case is, you drain the oil as soon as you receive the analysis results.
14 Forester XT
08 Civic LX (Auto)
#3242344 - 01/08/14 09:30 PM Re: Troubling UOA [Re: JMarshall]
Radiation_Joe Offline
Loc: PA
10k miles is not an unusual interval for an oil change on the current TDI diesels. There is certainly something else going on here. The VW TDIs don't perform forced regens of the the particulate filters so an excess of fuel in the oil is an indication of a fuel injection problem. I would take the car back to the dealer and ask them to confirm the injectors are performing properly.
What kind of fuel mileage are you getting? A current TDI should be seeing 30+ mpg city and nearly 40 on the highway at the least.
Edited by Radiation_Joe (01/08/14 09:31 PM)
#3242523 - 01/09/14 06:58 AM Re: Troubling UOA [Re: Radiation_Joe]
JMarshall Offline
Loc: NW PA
I will pull a sample at 4500 and see what happens.
I am getting the same mileage I always have, 33-35 in the city and 43 on the highway.
#3245502 - 01/12/14 01:21 AM Re: Troubling UOA [Re: JMarshall]
A_Harman Offline
Loc: Michigan
Aluminum, Copper, and Potassium have been trending down since new.
Chromium has been steady.
Iron jumped in the last UOA, along with the fuel.
The KV100 is borderline 20-weight.
The flashpoint is 50F lower than the last UOA.
The Castrol SLX 5w30 looks weak in both anti-wear and detergency.
Go to a thicker oil with higher anti-wear and shorten the OCI.
Since your car has a particulate trap, M1 5w40 ESP Formula M on a 5000 mile drain may be good.
Since the fuel dilution just started, I would take the UOA result to the VW dealer, get the issue on the record, and see if there is anything they can do about it.
Edited by A_Harman (01/12/14 01:30 AM)
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3245571 - 01/12/14 07:29 AM Re: Troubling UOA [Re: JMarshall]
Wilhelm_D Offline
Loc: Tacoma, WA
Latest UOA for my 2.0 CR Jetta TDI. Thoughts?
There have been some other UOAs for this same oil:
Jetta TDI 10302 miles
Jetta TDI 10183 miles
Jetta TDI 6934 miles
all of which show some of the same things your TDI is showing.
If it were mine I would try Mobil 1 ESP Formula M 5W-40 or Amsoil European Car Formula 5W-40 Synthetic Motor Oil with a 6,000 mile interval and see if the numbers improve.
Page 3 of 3 < 1 2 3
