1997 Saturn P0326 No power
by nwjones18
08/29/16 04:29 PM
Can I use lower weight ?
by ST2008
08/29/16 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
08/29/16 03:32 PM
Holdup
by Whitewolf
08/29/16 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
08/29/16 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
08/29/16 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
08/29/16 02:52 PM
Simple oil question, Honda GCV 160
by Popsy
08/29/16 02:49 PM
BMWs Remote 3D View
by HTSS_TR
08/29/16 02:25 PM
I changed my p.s. fluid, it's easy (with pics)
by TmanP
08/29/16 02:20 PM
Abandoning the Fumoto Valve Plan
by CrackyWainwright
08/29/16 02:18 PM
New Shed/Garage, A Couple Questions
by Bob5150
08/29/16 01:08 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
98 registered (2oldtommy, Al, 2015_PSD, 09_GXP, 8 invisible), 1743 Guests and 11 Spiders online.
58952 Members
66 Forums
253735 Topics
Page 2 of 3 < 1 2 3 >
#3241209 - 01/07/14 09:39 PM Re: Troubling UOA [Re: JMarshall]
Clevy Offline
Loc: Saskatoon canada
Try an hdeo. Or M1 0w-40.
Devlac makes a 0w-30 syn hdeo called devlac elite 222. I love the stuff.
Devlac also has a 0w-40 that is very stout too. I believe you need a stronger/thicker oil film since by looking at the report there is enough metal to make a jailhouse shiv
2006 Charger RT
Miles x 2 per oil filter
#3241224 - 01/07/14 10:02 PM Re: Troubling UOA [Re: Clevy]
dparm Offline
Loc: Chicago, IL
We can't get that stuff in the US.
2011 BMW M3 sedan ZCP
#3241230 - 01/07/14 10:08 PM Re: Troubling UOA [Re: JMarshall]
2004tdigls Offline
Loc: maple ridge, bc
if your car has the dpf and egr on the car you MUST use a low ash engine oil or the particulate filter will plug in short order
as others have suggested cut your OCI in half to 5000 miles and take a sample.
My dad used to say "oil is cheap, engines are expensive, so change your oil often and never change your engine"
I suggest you try this oil
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_ESP_Formula_M_5W-40.aspx
although it does not meet VW 507, it is a low ash oil
#3241235 - 01/07/14 10:10 PM Re: Troubling UOA [Re: JMarshall]
ram_man Offline
Loc: southern mo
Originally Posted By: JMarshall
Originally Posted By: ls1mike
What is cheaper? An engine or a couple of extra oil changes a year. I would not go 10K.
Definitely the oil. If I'm sitting on a ticking time bomb though, I want to trade it in before [censored] hits the fan.
Originally Posted By: simple_gifts
I don't know squat, but I'd do what B-S suggests; if a 5K interval produces 1/4 the wear...
I'd try to establish whether the wear is linear, or geometric etc.
Will do a couple shorter OCIs and see what it does.
Originally Posted By: volk06
Your engine has only had 3 oil changes in 30K. Thats about 3-5 less OCIs than the average person. While your wear is high its due to the long OCIs and the engine breaking in. If you want to see if you can get lower wear, do a few short OCIs and then sample. That oil looks WEAK as well. What oil is specified for this engine? It looks like it needs to move up to M1 0w40 if that is an approved oil. I'm assuming this is a diesel engine?
This is a 2011 VW Jetta TDI. I am running both the 10K mile oil changes specified by VW, as well as the Castrol SLX Pro LLO3 full synthetic 5W-30 that is both specified and factory.
Originally Posted By: spasm3
Did coolant somehow get in the oil? The K+ is lower but was really high initially.
I have had no coolant loss or leakage.
Originally Posted By: ram_man
3,000 mile oci never hurt anyone.
Actually, multiple UOAs have found that shorter intervals can actually increase wear in these VW TDIs
Funny you mention that when your engine is wearing the way it is. You show me one engine that failed because of 3,000 oil changes and ill back off my point. Just because a bunch of lab coat wearing scientist's say something doesn't mean its true. Ive seen uoa be very inconsistent with what they should be. Also werent scientists the same people who said pluto wasnt a planet and then it was and then it wasnt again? Like I said 3000 oci never hurt anyone.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3241258 - 01/07/14 10:42 PM Re: Troubling UOA [Re: JMarshall]
Bandito440 Offline
Loc: NYS
Yikes. That's certainly not our typically boring UOA. I would get a baseline at 3,000 and see what's happening from there. 10,000 is obviously too long for your driving habits by a long shot.
Is this thing under warranty? I'd probably consider Pennzoil Euro 5w-40 or Mobil 1 0w-40, or a synthetic HDEO like Rotella T6 if warranty isn't an issue. I would only be concerned about the DPF if you're burning a considerable amount of oil.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
#3241275 - 01/07/14 11:05 PM Re: Troubling UOA [Re: JMarshall]
Brybo86 Offline
Loc: Chicago, IL
I would contact vw and ask to speak with or have an engineer see these results
08 Honda Accord EX-L 2.4L RP 0w20 116k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 178k
95 Yamaha Jog
86 Kawasaki 454Ltd Valvoline 20w50 18k
#3241280 - 01/07/14 11:17 PM Re: Troubling UOA [Re: JMarshall]
Bandito440 Offline
Loc: NYS
One other note: if there is a severe service schedule in your owners manual, that's definitely where you need to be. 70% aggressive city driving does not a long OCI make.
#3241295 - 01/07/14 11:37 PM Re: Troubling UOA [Re: ram_man]
gathermewool Offline
Loc: New England
To be fair, I'd like you to show me one engine that failed because of 5,000 mile oil change intervals; actually, show me one engine that failed because of 7,500 mile oil change intervals. 3,000 mile OCI's in MOST applications is a waste - moving on... Cheers2
IMO, you should change the oil to a stouter, approved oil, run two shorter intervals, and then sample after the third shorter interval. I'm going to go out on a limb and speculate that your engine is just fine, and only needs a proper oil at a proper interval.
Also, while you say you drive 70% city, you're also putting a lot of miles on the car - 10k miles in < 6 months doesn't sound like this engine spends too much time at low temps.
Edited by gathermewool (01/07/14 11:38 PM)
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3241303 - 01/07/14 11:48 PM Re: Troubling UOA [Re: JMarshall]
rhhsiao Offline
Loc: Los Angeles, CA
Part of the problem may be a combination of your driving habits and the use of a biodiesel blend. There are definitely lots of instances where the use of biodiesel in the TDI increases the likelihood of fuel dilution of the motor oil. Fuel dilution is also a strong possibility when you're doing a lot of short trips. Do you have access to regular D2? I'd also shorten the OCI like everyone suggests to try to get the metals down/out. Once you isolate the problem you can start to extend the OCI back to the manufacturer interval.
#3241326 - 01/08/14 12:52 AM Re: Troubling UOA [Re: gathermewool]
ram_man Offline
Loc: southern mo
well its not all out failure but the saturn s series if not given 3000 mile oci will burn oil. Alot get so bad its like every tank of gas add a quart. And the only fix is a rebuild.
to say 3,000 mile oci increase wear is insane is my point. Is it a waste in most applications ? Yes I think so. However having one uoa after another that is bad. I would go back to 3,000 and see how it looks if its good then let it go a little longer but I would rather run it a little short and waste a little oil versus running to long and decreasing engine longevity.
#3241402 - 01/08/14 05:04 AM Re: Troubling UOA [Re: JMarshall]
INDYMAC Offline
Loc: Magnolia, TX
I won't comment on a diesel UOA, but did Blackstone switch to GC for fuel dilution determination.
If you value your TDI, then send your reports to Terry Dyson for interpretation and recommendation.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#3241447 - 01/08/14 06:44 AM Re: Troubling UOA [Re: INDYMAC]
DuckRyder Offline
Loc: Atlanta
All of the approved oils for this car are 5/30, Castrol SLX Professional (gold bottle) is the dealer oil. It doesn't have a great reputation in TDi circles.
Mobil 1 has an approved oil (ESP) as does LiqiMoly they are probably the 3 easiest to find.
I'd probably sample at 5000 (not necessarily change) and see how it does.
Also might not be a bad idea to get it on record with VW.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#3241463 - 01/08/14 07:01 AM Re: Troubling UOA [Re: rhhsiao]
JMarshall Offline
Loc: NW PA
No, all diesel in PA is B5 by mandate
#3241724 - 01/08/14 11:12 AM Re: Troubling UOA [Re: JMarshall]
rhhsiao Offline
I'd go with a short OCI, probably 5K miles, and do another UOA to see how things are shaping up. The one positive takeaway is that wear metals are trending down save for iron but definitely not fast enough.
#3241887 - 01/08/14 01:56 PM Re: Troubling UOA [Re: simple_gifts]
MolaKule Offline
Loc: Iowegia - USA
Saw that but the glycol test is 0. Wonder if that is a valid test for VW coolant.
The big question is, why is the Potassium trending downward?
Did the FF oil contain a lot of Potassium agent?
What does the VOA of this current oil show in terms of Potassium?
Edited by MolaKule (01/08/14 01:57 PM)
A guy asked me for two pieces of ID, so I tore my drivers license in half. smile
