I don't know if I messed anything up or not but im going to give a thorough story and see what kind of replies/help i get.
I got an E34 BMW 530i, 3.0 V8 M60B30. I changed the oil myself and I searched the internet and saw someone putting MB1 5w20 in their car and liking it. I think they originally came with castrol gtx 10w40.. I went with MB1 and changed the oil out (filter as well). After about a week, the car started with a bit of white/grey oil smoke. It blew off and I thought maybe the intake was dirty. I cleaned it with runrite from the hanging bottle running it through the MAF as well. The car blew off a lot of smoke as I drove it around the block.. I let it run and then I allowed the car to cool and it stopped.
The smoke continued... I noticed smoke at startup and again after idling for a few minutes at a red light or so. At this point I figured it was the valve stems. They could just be bad, but I was hoping to fix it with additives. First I added Gunk Bearin' Seal. Honestly this was just me being stupid, I thought it would seal up the valves and try to stifle the smoke problem. Naturally, it did nothing to notice and I decided to try White Shepherd. After adding the White Shepherd I noticed engine knock.
My one question that I am wondering about right now is since White Shepherd and Bearin' Seal are both additives that are as thin as water. Could adding these additives cause the knock by ruining the viscosity of the oil? I added 1 12oz Bearin' Seal and 2 8oz White Shepherd. (white shepherd instructions say to treat 4-6qts of oil and the M60B30 holds 9qts)
The car has 260k on the clock (bmw had an issue with nikasil blocks and this is probably actually much less, but I'm not taking away from the fact that the valves could just be bad and need replacing). When I got the car, the car had been sitting for the better part of 3-4 months.
I don't know if I can think of any more details that may help with any suggestions. My next move is to empty out the MB1 oil and replace it with 10w40 Valvoline Maxlife and stay away from White Shepherd entirely.
